Thread: A way to test HVAC units commands to blend door actuator?
Results 1 to 7 of 7
Fahrenheit A way to test HVAC units... 10-22-2015, 05:54 PM
MyLittlePony Re: A way to test HVAC units... 10-22-2015, 06:02 PM
Fahrenheit Re: A way to test HVAC units... 10-22-2015, 06:22 PM
Fahrenheit Re: A way to test HVAC units... 10-30-2015, 09:27 AM
Drive XR7 Re: A way to test HVAC units... 10-30-2015, 12:56 PM
Fahrenheit Re: A way to test HVAC units... 10-30-2015, 04:58 PM
Drive XR7 Re: A way to test HVAC units... 10-31-2015, 07:11 AM
  1. #1 A way to test HVAC units commands to blend door actuator?
    Jul 2010
    Philly
    Okay, passenger side HVAC would always blow hot no matter the sliders position on the HVAC unit. Figure it was the blend door actuator, got a new one but still hot all the time. So my replacement is a doormen unit so it could be bad right out of the box. The HVAC unit sends something to the blend door actuator because with the actuator plugged in the motor does spin but it only jitters half a turn back and fourth before giving up. The one that came out of the car does the same thing but the unit that came out was a "Woory" branded unit that I don't think it stock. So being the actuator only has 4 plugs on it couldn't I prob the harness with my multimeter and see what the HVAC is sending to the actuator? I figure, one of em is ground, the other 2 voltage for forwards and backwards then a sensor wire to tell the HVAC to stop sending voltage. Anyone got a wiring diagram for the area to make this a little more easy for me?
  2. #2 Re: A way to test HVAC units commands to blend door actuator?
    GT Level Member MyLittlePony's Avatar
    Mar 2015
    Franklin, TN
    Mine did the jitter back and forth a little, I had to replace my controls, if the blend door is bad it won't move, here is what I did, I pressed in on the control lever and noticed the blend door actuator move more.
  3. #3 Re: A way to test HVAC units commands to blend door actuator?
    Jul 2010
    Philly
    Quote Originally Posted by LS1Adam84 View Post
    That's what I was thinking but man i'd love to be able to test it before buying an ebay unit
  4. #4 Re: A way to test HVAC units commands to blend door actuator?
    Jul 2010
    Philly
    Did end up replacing the HVAC unit. Didn't try and do any testing since a local junk yard sold me one for 10 bucks. Everything works now, replacement unit even has all its bulbs lit. Just wanted to mark this as solved in case someone finds it in search
  5. #5 Re: A way to test HVAC units commands to blend door actuator?
    SE Level Member Drive XR7's Avatar
    Cleveland, OH
    I have the same issue. I need a dual slider HVAC unit, but they are hard to find used or are very expensive new.
    Jason
    2001 Bronzemist Pontiac Grand Prix GTP - SOLD!
    2003 Sonic Blue SVT Mustang Cobra Convertible #2421 (1 of 340)
    2013 Ruby Red Ford Edge Limited EcoBoost
  6. #6 Re: A way to test HVAC units commands to blend door actuator?
    Jul 2010
    Philly
    Ebay has a few for 50ish, I lucked out at my local junk yard though.
  7. #7 Re: A way to test HVAC units commands to blend door actuator?
    Cleveland, OH
    Quote Originally Posted by Fahrenheit View Post
    Yeah I just noticed that after posting this. A month or two ago there was nothing but brand new units. I'm local to Ed Morad so I sent him an email to check his inventory. If he doesn't have any I'll order one from eBay.
  1. Blend door actuator ! HELP!
    By JOlinsk20 in forum General Grand Prix Discussion
    Last Post: 08-20-2015, 01:25 PM
  2. [?] blend door actuator or HVAC control unit ???
    By localhost127 in forum General Tech Discussion
    Last Post: 08-25-2014, 06:58 PM
  3. Blend doo or Blend door actuator?
    By Logan541 in forum General Tech Discussion
    Last Post: 06-10-2014, 02:29 PM
  4. Blend door or actuator?
    By EJOUIE in forum General Tech Discussion
    Last Post: 05-05-2013, 11:00 PM
