Thread: exhaust and heat shield questions for my 05 GP
Results 1 to 10 of 10
  1. #1 exhaust and heat shield questions for my 05 GP
    GT Level Member kyliek23's Avatar
    Feb 2013
    So i replaced my resonator maybe 2 years ago if not maybe earlier. I went the cheaper route and got a Thrush glass pack, and got it welded. well since its so heavy I needed a new exhaust hanger other than pipe strapping. any ideas on where to go or what to use for an exhaust hanger. I tried some galvanized pipe strapping and screwed it to the bottom on my car, but that always seems to rust and break right away. would you think I could weld up another flange to the other end of the resonator that hooks onto another set of those rubber bushings? whats the best way to do this? because I can hear my exhaust rattling and vibrating my whole car because I have It securely hooked in another place. Another thing is the shield that protects my gas tank is broken and just hanging. I have had it fixed 2 times already with epoxy.
    I need some serious help.
    2005 Pontiac Grand Prix Base
  2. #2 Re: exhaust and heat shield questions for my 05 GP
    you can get this deal. weld one side to the bottom of the car, the other to the pipe bushing in the middle.
    no idea on the tank shield.
  3. #3 Re: exhaust and heat shield questions for my 05 GP
    Feb 2013
    grr ok. do you think the rubber bushing idea is a good one?? lol
  4. #4 Re: exhaust and heat shield questions for my 05 GP
    with out it you'll hear it vibrate. i can only assume you have it wired up now and is why your hearing it.
    all the other hangers are done this way on your car already. all have rubber bushings.
  5. #5 Re: exhaust and heat shield questions for my 05 GP
    Feb 2013
    yeah I have the actual flange with the rubber bushings already before the res right after the down pipe and cat. I just want to add another one to add to that so its quieter. so then the vibration on the galvanized pipe strapping "hangers" isn't there anymore.
  6. #6 Re: exhaust and heat shield questions for my 05 GP
    have you tried changing the round rubber hangers at the cat back flange? you would be surprised how small they are when new.
    once old they tend to be oval looking off the car, all stretched out.
  7. #7 Re: exhaust and heat shield questions for my 05 GP
    Feb 2013
    ill check them see what I can do.
  8. #8 Re: exhaust and heat shield questions for my 05 GP
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    Quote Originally Posted by ScottyDoggs View Post
    like a vagina ...
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  9. #9 Re: exhaust and heat shield questions for my 05 GP
    Feb 2013
    nice one EHB.
  10. #10 Re: exhaust and heat shield questions for my 05 GP
    Quote Originally Posted by EHB View Post
    like a vagina ...
    you know what? your spot on man lol
  1. Heat shield for my HAI
    By trey9778 in forum General Grand Prix Discussion
    Last Post: 12-24-2013, 11:40 AM
  2. Heat shield Help!!
    By alexstew15 in forum General Grand Prix Discussion
    Last Post: 08-13-2013, 07:25 PM
  3. heat shield from zzp worth it?
    By bps02gtp in forum General Tech Discussion
    Last Post: 12-03-2011, 09:58 AM
  4. Cut off heat shield?
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2008, 10:03 PM
  5. Heat shield with Plog?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2008, 09:17 PM
