I am addressing a few leaks on my 01 GTP. I know it has a power steering leak, because the pump whines loudly and I have to top it off often. I'm not sure if this is a power steering line, or a transmission line. I checked both today, and found both to be low.
It's a red fluid that is leaking from this spot, doesn't smell like anything particular. I am using Lucas Power Steering Stop Leak, which is also red. The Dextron is also red, so I'm not sure what kind of line this is. It leaves a sizable puddle, as you can see from these pics. This was after sitting for only 10-15 mins or so. These lines are located at the front of the car, underneath the cooling fans. They are rusty, and I've tried to illuminate them as best I could with a flashlight so you can see. You can also see clearly how the air dam is cover with this fluid as it leaks quickly.
They are illuminated, rusty:
Notice the puddle that has formed after only 15 mins:
