Thread: Catch Can and Vac Pump are installed
Results 1 to 4 of 4
  1. #1 Catch Can and Vac Pump are installed
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Catch can and vac pump are installed. Still waiting to test it out.
    The vac pump is on a hobb switch so it will only come on when in boost. This will help relieve the crank pressure and blow by I'm getting which I think is the reason for my misfire at high boost and rpm.
    Going to put thermo wrap around pump to keep heat from turbo away from it.
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  2. #2 Re: Catch Can and Vac Pump are installed
    Thats is pretty fancy.
  3. #3 Re: Catch Can and Vac Pump are installed
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    That looks kinda yummy. Are you misfires primarily from the rear head cylinders? I see that you're already vented on the front valve cover.
  4. #4 Re: Catch Can and Vac Pump are installed
    Feb 2008
    NY
    Quote Originally Posted by JamesIvey24 View Post
    That looks kinda yummy. Are you misfires primarily from the read head cylinders? I see that you're already vented on the front valve cover.
    i'm getting a misfire at 18lb of boost and 5500 RPM and higher. The car screams at WOT. The breather was really expanding when on dyno. I changed everything ignition related. Being this misfire started after I upgraded to the T70, I believe it's pressure related.
    Besides this should make the car run better.
  1. Phenolic IC installed!! Pump location fixed!!
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-08-2015, 08:54 AM
  2. catch can / air pump & PCV setups
    By DJNight2k in forum Turbo
    Last Post: 09-16-2013, 03:04 PM
  3. New Fuel pump installed
    By jessemerle in forum General Grand Prix Discussion
    Last Post: 02-08-2013, 07:22 PM
  4. I wonder if this is going to catch on....
    Last Post: 01-28-2011, 07:25 PM
  5. Replies: 4
    Last Post: 02-04-2010, 07:50 PM
