Thread: squeel from front end only from 1 to 2 MPH
Results 1 to 20 of 21
  1. #1 squeel from front end only from 1 to 2 MPH
    Nov 2011
    Indiana, PA
    if I am sitting at a complete stop on a flat lot then take my foot off the brake as the car starts to creep forward it starts to squeal almost like a rubbing noise the pitch will change lower as it stops and higher as it gets from 1 MPH to 2 MPH after 2 MPH it's silent or at least I can't hear it...
    car was realigned, nothing changed...
    car had ball joints changed, nothing changed...
    new brakes, nothing changed...
    tires have the correct air pressure for the car (30 PSI according to the door sticker)
    is this a sign of a bad wheel hub? or something else?
    no steering noise causing this, the car is doing this going perfectly straight when this happens...
    the noise is only loud enough to hear if I have the window down, it's coming probably from the front drivers side from the sound of it..... roll the windows up I can barely hear the noise inside, but you definitely can outside
    this is a 2008 base GP
  2. #2 Re: squeel from front end only from 1 to 2 MPH
    bent dust shield rubbing the rotor?
  3. #3 Re: squeel from front end only from 1 to 2 MPH
    Nov 2011
    Indiana, PA
    Quote Originally Posted by WileyCoyote View Post
    nope, had that checked also....
  4. #4 Re: squeel from front end only from 1 to 2 MPH
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    open the hood and have someone idle it forward while you try to pin point where the noise is coming from... i'm sure you can keep up at that speed.lol
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  5. #5 Re: squeel from front end only from 1 to 2 MPH
    GrandPrix Junkie
    St. Louis
    Maybe the pads are dragging a bit. Check to be sure the caliper is able to slide freely. Might be hanging up just enough to squeak the pads until you get moving faster.
  6. #6 Re: squeel from front end only from 1 to 2 MPH
    Nov 2011
    Indiana, PA
    Quote Originally Posted by EHB View Post
    ha, tried that before but can't pinpoint it enough without getting ran over!.. it sounds like its coming from around the axel... its not a rubbing metallic noise but like a rubber noise (like a rubber ducky squeak but drawn out and one long noise like sqqqqqueeeeeeeeeeeeeeeeeeeeeeeeekkkkkkkkk until the car is fast enough)... it's hard to explain... I need to somehow record the noise...
  7. #7 Re: squeel from front end only from 1 to 2 MPH
    Dec 2014
    Maryland
    put roller skates on and hang onto the car
  8. #8 Re: squeel from front end only from 1 to 2 MPH
    Feb 2013
    37.295091, -121.930053
    Uhhhh video would help. Since it's low speed noise I ghettovet you can set your phone there to record it
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: squeel from front end only from 1 to 2 MPH
    Dec 2014
    Maryland
    put the car on jackstands and see if it still does it.
  10. #10 Re: squeel from front end only from 1 to 2 MPH
    Nov 2011
    Indiana, PA
    it's only when the wheel has a load on it, no load it's silent
  11. #11 Re: squeel from front end only from 1 to 2 MPH
    Feb 2013
    if it needs a load to make the noise it more like the bearing has no lube or is going out.
  12. #12 Re: squeel from front end only from 1 to 2 MPH
    Dec 2012
    Where 4T65E's were born
    My bearing did the same thing.
    https://youtu.be/gXSSyLOiuvU
    Just yesterday a gp was pulling out of the shop and made the same noise. I was like hey my car used to do that lol.
    Sold.
  13. #13 Re: squeel from front end only from 1 to 2 MPH
    sounds like its singing lol
  14. #14 Re: squeel from front end only from 1 to 2 MPH
    Dec 2012
    It made that noise for the first few feet you drove after its sat and cooled down, and on turns.
    Going through parking structures was always interesting. It was pretty loud echoing through the whole level, people would often look at what was making that odd noise.
    Sold.
  15. #15 Re: squeel from front end only from 1 to 2 MPH
    Nov 2011
    Indiana, PA
    sounds very close to what I am hearing, probably a bit different since it's probably not the same design wheel hub on an 08 but it seems like the hotter the engine bay gets the more it will squeal, it will some when cold but when warm its louder
  16. #16 Re: squeel from front end only from 1 to 2 MPH
    Dec 2012
    Should be the identical bearing
    Sold.
  17. #17 Re: squeel from front end only from 1 to 2 MPH
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    sit on the car with hood popped and let it go the 2 mph. thats only thing i can think of. My car did this, when it was going below 10 mph, apparently one of rear trailing arms was upside down?? Doesn't make it anymore, but happened after i put the trailing arms in.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  18. #18 Re: squeel from front end only from 1 to 2 MPH
    Nov 2011
    Indiana, PA
    I'm really thinking its the front driver wheel bearing now, I noticed it today going about 15 miles an our a squeak squeak squeak with the wheel turning... almost like just part of the hub is bad when it rubs that part, but that's odd since below 5 mph how its just a consistant squuuuuuuuueeeeeeeeeeeeeeak until it stops,,, and consistant until it gets about 10+MPH then starts the squeak squeak squeak, at about 20mph it goes away compeltely
  19. #19 Re: squeel from front end only from 1 to 2 MPH
    Aug 2012
    Brainerd, MN
    I normally get more noise going faster with wheel hubs can get a set of wheel hubs for 50-60, but thats my .02.
  20. #20 Re: squeel from front end only from 1 to 2 MPH
    Nov 2011
    Indiana, PA
    Quote Originally Posted by Mirraco View Post
    yeah, hubs aren't to expensive... trying to be a bit cautious about this though since I already replaced a sway bar, sway links, two ball joints..... adds up fast ha... need to record the sound, been raining for days though so never get around to it
  1. Smoke from front of engine even after Front Valve Cover Gasket replaced
    By rpenlington in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-13-2013, 12:57 PM
  2. GMPP front and rear sway w/ front STB
    By FordMan77 in forum General Grand Prix Discussion
    Last Post: 10-31-2012, 03:04 PM
  3. Ok soo Pulley squeel. This sucks
    By chevyy1212 in forum General Tech Discussion
    Last Post: 11-08-2011, 10:22 PM
  4. Left turn high pitch Squeel
    By drumboy722 in forum 04+ Specifics
    Last Post: 10-07-2009, 03:49 PM
