Thread: Ok soo Pulley squeel. This sucks
Results 1 to 20 of 23
  1. #1 Ok soo Pulley squeel. This sucks
    GTP Level Member chevyy1212's Avatar
    Oct 2008
    IL
    Its not happening all the time more when it gets colder ofcourse. Seems to go away at higher rpms but is getting worse even then. Oh and I got new belts all around. Its not qwite a squeel like a whine squeel comes and goes.
    I spun all the pulleys and the alternator makes a slight rattle sqeekish and the PS pulley doesnt spin easy but thats expected on the PS
    I know its not from the S/C. My power steering pump is close to calling it qwits that pulley has a tiny tiny bit of play if I try crazy hard and a wobble that you cant almost notice when running. It sounds much more like the alternator or tensioner.
    So my main questions for whoever is
    1. Is there any crap besides the belt dressing like somthing I can spray into the pulley to make it stop to narrow it down.
    1(again). Can the power steering pulley make the squeelish>
    2. How hard is it just to swap tensioner pulley? Just clockwise to take the nut off and then work the pulley off or should I just replace the whole damn thing?
    3. How the hell do you guys usually narrow down which one is being a lil ****?
    Thanks again this sucks
    1998 GS with Open cone, PLOG, ZZP Catless DP, tune & Intense MPS 3.6. Pulls good enough to make the woman smack me and call me a D!*k.
  2. #2 Re: Ok soo Pulley squeel. This sucks
    Oct 2008
    IL
    Well its not the tensioner pulley... Its like a grind whine. I know its bearings going out.
  3. #3 Re: Ok soo Pulley squeel. This sucks
    Don't use belt dressing it's really bad to use it builds up in the grooves.
  4. #4 Re: Ok soo Pulley squeel. This sucks
    Jun 2011
    Detroit, MI
    Well its probably not the ac compressor, that usually sounds like a knock.. I would put some of your favorite lube like WD-40 (ACCURATELY) on part of the alternator that would be prone to squeaking.., and maybe the tensioner, if possible. See if it goes away then..
    Good luck.
    iLoveSpade
  5. #5 Re: Ok soo Pulley squeel. This sucks
    Oct 2008
    IL
    Good to know thanks
    Quote Originally Posted by Hippo Machine View Post
    Good luck.
    Well I just replaced the tensioner pulley a hour ago so that not it. Its not coming from anywhere near the AC. Where would I spray on the alternator?
  6. #6 Re: Ok soo Pulley squeel. This sucks
    Jun 2011
    Detroit, MI
    Quote Originally Posted by chevyy1212 View Post
    Good to know thanks
    Probably anywhere but the coil or belt, i know mine squeaked when new, maybe they squeak when old too.
    iLoveSpade
  7. #7 Re: Ok soo Pulley squeel. This sucks
    Oct 2008
    IL
    Ill give it a shot I plan on buying one anyway so if I screw it up whatever. You ever heard of shops rebuilding them still? I heard its cheaper better quality and work here not china
  8. #8 Re: Ok soo Pulley squeel. This sucks
    Jun 2011
    Detroit, MI
    nah, I just got mine from oreilly's it was $80 i think remanned delphi i believe.
    iLoveSpade
  9. #9 Re: Ok soo Pulley squeel. This sucks
    Oct 2008
    IL
    I just got a used one off ebay for $25. We will see if it does the trick. So Im only $45 into my squeeky pulley chase not bad. After this its a new power steering pump atleast thats something I actually need.
  10. #10 Re: Ok soo Pulley squeel. This sucks
    You mention your ps is an issue, right? Probably causing a load on the belt etc.
    The pump should turn easily by hand. Not fast..but easily.
  11. #11 Re: Ok soo Pulley squeel. This sucks
    Oct 2008
    IL
    Ill double check that tonight. Im pretty sure tho it turned rather easy.
  12. #12 Re: Ok soo Pulley squeel. This sucks
    ...and the PS pulley doesnt spin easy but thats expected on the PS
    .....My power steering pump is close to calling it qwits that pulley has a tiny tiny bit of play if I try crazy hard and a wobble that you cant almost notice when running.
    When I read your post.. I'm not sure why, but you highlighting the ps pump for us... it kinda stuck in my mind.
  13. #13 Re: Ok soo Pulley squeel. This sucks
    Oct 2008
    IL
    Yea its a issue. Im hoping its not actually the rack & pinion tho. Seems to be a little clunk in the steering when I turn the steering wheel back and forth
  14. #14 Re: Ok soo Pulley squeel. This sucks
    Well..if you are looking for a squeal, I'd be looking at what you highlighted.
    Wink wink..look at the ps closer.
  15. #15 Re: Ok soo Pulley squeel. This sucks
    Oct 2008
    IL
    Lol yea Im going to for sure. So you would know is this a swap I can do in my driveway? Im doing the return line and pressure too? Looks just like it will be cramped as hell
  16. #16 Re: Ok soo Pulley squeel. This sucks
    If you crawl under..you can do it. Yes it's tight. Its possible though.
  17. #17 Re: Ok soo Pulley squeel. This sucks
    Grand Rapids, MI
    well you can buy an automotive stethascope at sears for like $10. i bought one. helped me figure out quite a few things. like on the van, we have what sounds like rocks rolling around in the belt area. turns out the alternator bearings are crapped out. it's very useful. might try it and listen around before thoughts of buying racks and pumps and what not.
  18. #18 Re: Ok soo Pulley squeel. This sucks
    Oct 2008
    IL
    Well I just had a buddy/shop narrow it down for me. My rack is good is my PS pump is good its my pressure hose that is screwed. He also said my tensioner for S/C is done but that wasnt the noise anyway cuz it still made it after I took off the SC belt. He spun my alternator.. Said that the alternator bearings were on there way out. I thought it may have been that but went for the tensioner pulley first $18 bucks gonel. Oh well got a alternator off another Regal to throw on while I take mine to get rebuilt.
  19. #19 Re: Ok soo Pulley squeel. This sucks
    Jun 2011
    Detroit, MI
    I thought it was the alt. surprised lube didn't help, glad you found the source though.
    iLoveSpade
  20. #20 Re: Ok soo Pulley squeel. This sucks
    Oct 2008
    IL
    I actually didnt get a chance to lube it before I read our post and got the other one off another Regal. It was so intermediate that it was hard to pinpoint but I knew it was coming from the top back. I got the used one and theres an shop that rebuilds them for half of what a China rebuilt will cost so Ill take the 30 minute drive and have some American hands rebuild my stocker.
  1. Well this sucks. What would you do?
    By DBGP in forum The Rant Forum
    Last Post: 01-31-2012, 05:02 AM
  2. this sucks
    By ammojunkie in forum General Tech Discussion
    Last Post: 12-30-2009, 05:39 PM
  3. wow this sucks
    By Will5600 in forum General Tech Discussion
    Last Post: 11-23-2009, 07:23 PM
  4. Left turn high pitch Squeel
    By drumboy722 in forum 04+ Specifics
    Last Post: 10-07-2009, 03:49 PM
  5. ZZP (sucks)
    By 98GTPCALGARY in forum The Rant Forum
    Last Post: 04-08-2009, 07:24 AM
