Thread: Steering wheel misalignment
Results 1 to 20 of 24
  1. #1 Steering wheel misalignment
    Massachusetts
    I noticed after having my state inspection done to the vehicle that the steering wheel is now misaligned. The car steers straight down the road but the steering wheel is now cocked about 30-40 degrees. ?
  2. #2 Re: Steering wheel misalignment
    id go back and ask, hey wtf you do to my car here?
  3. #3 Re: Steering wheel misalignment
    Jul 2010
    Coquitlam,BC,Canada
    If your inspections are similar to our inspections, your mis-aligned steering wheel could not happen during an inspection.
    Signed,
    Ex Vehicle Inspector.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  4. #4 Re: Steering wheel misalignment
    Massachusetts
    So Bronco Boy you're saying it happened out of the blue? I don't think so. I've contacted him and he said to bring it back. He used a floor jack to jack up one side of the car at time to inspect the front wheels for loose ball joints etc. He left the motor running while he did this. I noticed the issue with the steering while shortly after I left there. So, you still think he had nothing to do with it? The car has less than 68,000 miles on it. I have maintenance performed before items become due. I stay on top of things. No, this just did not happen out of the blue. I'm asking here trying to get an idea of what may have caused this and what to look for.
  5. #5 Re: Steering wheel misalignment
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by GPCharlie View Post
    Out of the blue? No. By a guy inspecting your vehicle? Unlikely. Think of what is involved to get the wheel that far off. Unless the inspector did something stupid, he wouldn't have done anything to effect the wheel this much. I've been doing inspections on and off for almost 30 years, and have yet to have a story like yours be the fault of the inspector. See coincidence.
    One time I helped a customer by topping up his power steering fluid that he bought from me. Two days later he is back blaming me for breaking his power steering pump. See coincidence.
    Quote Originally Posted by HighOctaneRacing View Post
    The inspector probably jacked it up by the inner tie rod
    Definitely a possibilty.
    Most likely.. you didn't happen to notice it was slightly off before.
    ^ This gets my vote.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Steering wheel misalignment
    Jul 2010
    Coquitlam,BC,Canada
    Like HighOctaneRacing said,the inspector may have jacked it up by the inner tie rod.
    Or he removed the wheel and put it back in the wrong position.
    Or he disconnected the steering at the rack and put it back in the wrong position.
    The first one is the only one that I can see as being possible. But unlikely as you never mentioned the car was pulling to one side or dragging.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Steering wheel misalignment
    Quote Originally Posted by Bronco Boy View Post
    none of this is possible. id like to see how a jack gets past the sway bar and hits the tie rod.
  8. #8 Re: Steering wheel misalignment
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by ScottyDoggs View Post
    Anything is possible, thus this thread. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: Steering wheel misalignment
    Enfield, CT
    Sent from my LG G3
  10. #10 Re: Steering wheel misalignment
    Inspectors here jack them up by the drip edge.
    I'd like to hear how he got the jack on an inner tie rod considering how the frame and control are are in the way. Plus..one tie rod would make it steer badly.
  11. #11 Re: Steering wheel misalignment
    Enfield, CT
    Lol no crap
    Sent from my LG G3
  12. #12 Re: Steering wheel misalignment
    Inspectors in MA don't remove wheels and if you go try to jack up your inner tie rod with a wheel on.. I give you kudos if you can catch it with a jack.
    The subframe and control arm and sway bar are all in the way of you catching it.
  13. #13 Re: Steering wheel misalignment
    Jul 2010
    Coquitlam,BC,Canada
    They don't remove wheels? ?!? No brake inspection?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: Steering wheel misalignment
    Enfield, CT
    Don't have photos on me but look here. Last photo.
    You can definitely hit the inner but you'll also be hitting the outer a bit too.
    http://www.w-body.com/topic/30087-en...g-install-fe3/
    Sent from my LG G3
  15. #15 Re: Steering wheel misalignment
    Sent from my LG G3
    Hi...I'm BillBoost
    Now cut yer crap boy!
  16. #16 Re: Steering wheel misalignment
    not with the tires on the car your not.
  17. #17 Re: Steering wheel misalignment
    Enfield, CT
    Lol
    Sent from my LG G3
  18. #18 Re: Steering wheel misalignment
    Feb 2013
    37.295091, -121.930053
    bill im suprised your not a mod on that forum to
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  19. #19 Re: Steering wheel misalignment
    Enfield, CT
    Too early
    Sent from my LG G3
  20. #20 Re: Steering wheel misalignment
    Massachusetts
    I'm sure that I would have noticed it starting to happen. I pay attention to details like that. Kind of anal in that regard. If the inspection did not cause this then what can? Just trying to understand why it happened and what I need to do to fix it.
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  3. Wanted: Steering wheel cover/Steering wheel - 2005 Grand Prix GXP
    By killuminati in forum Wanted To Buy - Parts
    Last Post: 02-02-2014, 03:22 PM
  4. Door Misalignment
    By jcmonteman in forum General Tech Discussion
    Last Post: 06-15-2011, 09:02 AM
  5. Crankshaft Pulley MisAlignment
    By Mikey2769 in forum General Tech Discussion
    Last Post: 06-29-2009, 11:49 PM
