Thread: Rocker panel trim
Results 1 to 20 of 23
  1. #1 Rocker panel trim
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    My new to me 02 GTP is starting to have the rocker panel trim on the bottom of the door curl and come loose. Obviously it appears the double sided tape has failed/is failing. I've heard the 3M super strength stuff is good to reattach it. What can be done about the slight curling on the end? Heat gun and straighten it out? Also where can I find replacement clips? Mine look busted.
  2. #2 Re: Rocker panel trim
    Jul 2010
    Coquitlam,BC,Canada
    Curl? You sure? That piece is pretty rigid, and would take a lot to make it "curl".
    Here are some pics: http://chrisb.users.superford.org/Gr...r_Molding.html
    I used ProForm tape to re-attach things. Clips are OE, junk yard or auto parts store.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  3. #3 Re: Rocker panel trim
    Dec 2014
    Upstate, NY
    Is the part right under the door curling outward, towards the side of the car, or is it at the end near a wheel? Do you have pictures?
    If it is in the middle right under the door and curling away from the car, I'd check behind it, as you might have rusted rocker panels behind the rocker panel trim.
  4. #4 Re: Rocker panel trim
    Enfield, CT
    Used the 3M stage 3 double sided tape on the gf's 03 GP. Works flawlessly provided you use the 3M rubber wheel to get all the old crap off.
    Sent from my LG G3
  5. #5 Re: Rocker panel trim
    Jan 2014
    AR
  6. #6 Re: Rocker panel trim
    Feb 2009
    Roanoke, VA
    Quote Originally Posted by jimmyfloyd View Post
    http://imgur.com/fcPma05
  7. #7 Re: Rocker panel trim
    Jan 2014
    AR
    Both my 99 coupes have an original equipment screw inside the door jamb at that spot. Does yours?
  8. #8 Re: Rocker panel trim
    Feb 2009
    Roanoke, VA
    Quote Originally Posted by idrivejunk View Post
    Nope, no holes in it at all.
  9. #9 Re: Rocker panel trim
    Jan 2014
    AR
    Well, we've stumbled onto something that appears to be a year-to-year difference. 99s have a very thin flange where the tape goes but with a screw boss there and the molding is paper-light. But I just looked at the pair of 2002 moldings I have, and the tape area is not a flange, its really thick and solid at the top instead. Obviously a revised part. Thats good news, you can probably re-tape yours. Do the best you can to clean it without peeling it off more, then re-tape that spot and hold it flat with tape then warm the whole area with a hairdryer enough to relax the plastic. Mash hell out of it while its hot, then let that cool down and mash again and un-masking-tape it and see how long it holds. Might take 2 or 3 tries but I don't think yours is very bad yet so you might make a permanent fix.
  10. #10 Re: Rocker panel trim
    Feb 2009
    Roanoke, VA
    Well the bottom trim is completely gone so the door molding flaps open with the door shutting haha. It seems I'm going to have to pull it all and clean it and re-tape it all.
  11. #11 Re: Rocker panel trim
    Jan 2014
    AR
    Quote Originally Posted by Brammer View Post
    Aw heck, yeah you did say it was flappin in the breeze, didn't ya? Well, count your blessings since it appears you have the sturdier molding design. Those early ones rip really easy. Make every effort to keep the molding flat as you remove it, and do use a little heat if the molding is still curled after cleaning. You'll have to get lucky at either a yard or dealer to get replacement clips n strip but those shoudn't cost much. FWIW you could carefully drill then put a short screw there to avoid a repeat. Good luck!
  12. #12 Re: Rocker panel trim
    Enfield, CT
    Quote Originally Posted by HighOctaneRacing View Post
    Sent from my LG G3
    This is the permanent fix...
    Sent from my LG G3
  13. #13 Re: Rocker panel trim
    Jul 2010
    Coquitlam,BC,Canada
    Looks like somebody reefed on that corner.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: Rocker panel trim
    Jul 2010
    Coquitlam,BC,Canada
    It is tape, thus can't be called "permanent". LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  15. #15 Re: Rocker panel trim
    Enfield, CT
    Quote Originally Posted by Bronco Boy View Post
    Hey never had an issue after that
    Sent from my LG G3
  16. #16 Re: Rocker panel trim
    Jul 2010
    Coquitlam,BC,Canada
    If it is permanent, then you will never have the problem again. You gots a 50% chance of being right. LOL
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  17. #17 Re: Rocker panel trim
    Enfield, CT
    I'll take my chances. You also have to understand that the technology and materials to make double side taped has gotten much, much better since the late 90's and early 00's.
    Sent from my LG G3
  18. #18 Re: Rocker panel trim
    Jul 2010
    Coquitlam,BC,Canada
    Oh I know. I was just havin' fun. I used 3m tape to install the HID ballasts on my T-bird, mounted to the bottom of the bumper, -10*C or so, and a heat gun. 4 years later they were still there. Prep is key. I have no sympathy for folk that say their tape failed. BS. I hear it 20 times a day at work, and it is still BS.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  19. #19 Re: Rocker panel trim
    Feb 2009
    Roanoke, VA
    Reefed?
  20. #20 Re: Rocker panel trim
    Jul 2010
    Coquitlam,BC,Canada
    Reefed?
    Pulled. Tugged. Yanked. Pryed.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. WTB: Lower door trim and rocker panel skirts for coupe
    By Dancing Bear in forum Wanted To Buy - Parts
    Last Post: 06-19-2015, 01:40 PM
  2. trying to add door panel trim lights
    By bocou92 in forum Audio, Security & Visual Electronics
    Last Post: 02-14-2014, 07:40 PM
  3. rocker panel or quarter panel??
    By ad356 in forum General Tech Discussion
    Last Post: 12-08-2013, 08:42 AM
  4. How to repair your door panel trim
    By JesseBranham in forum How To Write-Ups/Tech Tips
    Last Post: 07-25-2012, 08:11 PM
