Thread: New sway bar, linkage, now steering wheel is off.
Results 1 to 2 of 2
  1. #1 New sway bar, linkage, now steering wheel is off.
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    I looked at my suspension one day when car was on a lift, and the linkage was all cracked after 15k miles. I ordered heavy duty linkages, they were coming one day, so i took the one side tire off, loosened the linkage and my sway bar broke on the top part of it clean off. bottom part is still there, but it looks like a common problem with these hollow sway bars.
    Anyways, i got the sway bar ordered, im 70$ deep as of now, and a extra set of linkage for the car now. When installing, I had to remove the tie rod from the knuckle, I didn't take the tie rod off the inner tie rod, just took the castle nut off, and moved it all the way up so i could get the two bolts holding the sway bar to the frame.
    Now my steering wheel sits at like 1 o'clock, it was dead center. Do I need a alignment? I would prefer not to ruin a set of tires, but this car is getting aligned every month it seems like. Since feb I have aligned it 4 or 5 times.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  2. #2 Re: New sway bar, linkage, now steering wheel is off.
    make sure you got the tie rod end all the way back in the knuckle, other then that not much else can cause that.
  1. Steering linkage.
    By Blake71091 in forum General Grand Prix Discussion
    Last Post: 09-16-2014, 09:25 PM
  2. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  3. Wanted: Steering wheel cover/Steering wheel - 2005 Grand Prix GXP
    By killuminati in forum Wanted To Buy - Parts
    Last Post: 02-02-2014, 03:22 PM
  4. Steering linkage broke?
    By NinetyEightGTP in forum General Tech Discussion
    Last Post: 08-30-2013, 01:20 PM
  5. Steering Linkage!
    By blckgtp in forum General Tech Discussion
    Last Post: 05-31-2009, 03:34 AM
