Thread: Steering linkage broke?
Results 1 to 3 of 3
  1. #1 Steering linkage broke?
    Jun 2012
    Southern NJ
    I was doing the "lower subframe cam install" and it seems that the steering linkage is broken. Wheel spins freely.
    What do I do now, and where would it have most likely broken?
  2. #2 Re: Steering linkage broke?
    HUDSON
    Sounds like the steering shaft came off the rack and pinion, or the steering shaft on the column slid apart.
  3. #3 Re: Steering linkage broke?
    Aug 2013
    mpls, mn
    U dropped rear subframe and did not remove rack bolts? Or remove u-joint pinch bolt?
  1. Steering wheel spins freely, what broke?
    By aeidian in forum General Tech Discussion
    Last Post: 07-26-2012, 11:58 PM
  2. HELP! Power Steering Bolt Broke Off in Block
    By jpearsall187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-20-2011, 03:26 PM
  3. Booger I broke Power Steering line
    By SDGTP99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 10:08 AM
  4. Steering Linkage!
    By blckgtp in forum General Tech Discussion
    Last Post: 05-31-2009, 03:34 AM
  5. Shifter Linkage
    By J_Ferguson in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2008, 01:57 PM
