Thread: Steering wheel misalignment
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: Steering wheel misalignment
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by GPCharlie View Post
    If the inspection did not cause this then what can?
    See posts 3-19. We discussed any and all possibilities.
    Just trying to understand why it happened and what I need to do to fix it.
    Did you do what post #2 asked?
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  2. #22 Re: Steering wheel misalignment
    Massachusetts
    Yes, I've already done what post#2 suggested. He offered to straighten the wheel, albeit at my expense. Is there any component in the steering system that could be failing that would cause this to happen?
  3. #23 Re: Steering wheel misalignment
    Jack it up and make sure the rack bolts aren't loose. Look over the various things like the tie rod ends and inners etc. Wiggle the wheels while it's up. If you don't find play.. sorry to say, but it was in your head.
    Either that.. or your car is so rusted the subframe moved when it was jacked up..but then..it would have moved as you went over good bumps.
  4. #24 Re: Steering wheel misalignment
    Massachusetts
    Well, here's where I'm at with this so far. Took it to Sullivan Tire and had it looked at. They found the fasteners for the struts loose which also caused the camber to come out. The holes in the struts should be slotted so that the camber can be adjusted. They are round. I had the car to the Buick dealer two years back for replacement of the wheel hub assemblies. At that time they informed me that I needed an alignment. I said perform the alignment. Because the strut holes are round and not slotted I now wonder what the specs of the alignment were when they finished. They never gave me a printout like the one that I got from the tire store. The factory service manual goes into detail about having to slot the holes to be able to perform the camber adjustment. Guess one cannot educate oneself too much in the area of car repairs.
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. shaking steering wheel after wheel bearing replacement
    By vandezand in forum General Tech Discussion
    Last Post: 05-14-2014, 04:02 PM
  3. Wanted: Steering wheel cover/Steering wheel - 2005 Grand Prix GXP
    By killuminati in forum Wanted To Buy - Parts
    Last Post: 02-02-2014, 03:22 PM
  4. Door Misalignment
    By jcmonteman in forum General Tech Discussion
    Last Post: 06-15-2011, 09:02 AM
  5. Crankshaft Pulley MisAlignment
    By Mikey2769 in forum General Tech Discussion
    Last Post: 06-29-2009, 11:49 PM
