Thread: 94 GTP Questions
Results 1 to 9 of 9
  1. #1 94 GTP Questions
    Oct 2012
    TimbuckToo
    My Daughter still has her 94 GTP which is now handed down to my youngest daughter, only has 94k on the clock. Was going over the car and i find that the electric locks/remote and electric mirrors are not working, i have checked the fuse #7 for the locks and it appears to be ok, i went in the trunk and tried the jumper wire from the programming wire to the antenna and they do not cycle either. When i put the car in drive both locks engage, and they disengage when i put it in park....., is there another fuse or any suggestions on what to check on this electric lock issue or the electric mirrors? I could not find a fuse for the electric mirrors in the manual???
    TIA
    Oh i posted images of when my duaghter first go the car back in 2012, here's a link to the original pics http://www.grandprixforums.net/threa...657#post900657
    and it still looks and runs awesome...here is a pic of the car now..
    94 GTP Questions Attached Images
  2. #2 Re: 94 GTP Questions
    sorry no idea, but your daughters were raised right when it comes to car care, that car looks almost new.
  3. #3 Re: 94 GTP Questions
    Oct 2012
    TimbuckToo
    Thanks SD, im sure one of these Pontiac Guru's will know something more than me. :cheers
  4. #4 Re: 94 GTP Questions
    Oct 2012
    TimbuckToo
    Hard to believe no one has had similar issues with another Pontiac. I've tested everything....is it possible it could be a bad lock module...the one mounted under the rear window dash pad?
    Anyone know anything of what to look for on the mirrors?
  5. #5 Re: 94 GTP Questions
    problem is, theres not a lot of your year car here.
    most are 97-08
  6. #6 Re: 94 GTP Questions
    Oct 2012
    TimbuckToo
    Thanks SD, I had figured that pontiac didn't change much, as i've been in a few of the newer ones, and alot of the buttons and layouts looked the same, i was just hoping for some type of a starting point of where to look even if its from a lot newer car.
  7. #7 Re: 94 GTP Questions
    SE Level Member chadh8806's Avatar
    Sep 2015
    Had one just like that in high school and loved it.
    -Chad
    2001 Grand Prix GTP Special Edition -stock
  8. #8 Re: 94 GTP Questions
    hangover park IL
    a better site with more info would be w-body.com with more of a 96 and older GP/W body following.
    ~James~ Psychotic Gearhead
  9. #9 Re: 94 GTP Questions
    Oct 2012
    TimbuckToo
    Thanks Turbocharged400scb i'll give that a shot.
  1. Window Tint Questions and Rear Speaker Questions
    By Wisconnie in forum General Grand Prix Discussion
    Last Post: 06-22-2013, 07:17 PM
  2. 05 gxp hub questions
    By jteske88 in forum Brakes/Suspension/Chassis
    Last Post: 12-02-2012, 01:28 AM
  3. Replies: 2
    Last Post: 01-30-2012, 09:40 AM
  4. Few new questions.
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-15-2011, 08:43 PM
  5. Alky Questions & Other Related Questions.
    By rynoman03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-22-2010, 07:57 AM
