Thread: Replaced alternator, turning slow.
Results 1 to 7 of 7
  1. #1 Replaced alternator, turning slow.
    Nov 2011
    Michigan
    2006 grand prix base.
    I just replaced my alternator because of how overcharged it was. In idle it was nearly 15.4 battery volts. So i replaced it and now all of a sudden when i start the car, it slowly starts up. I don't get it. Both the battery and belt is a year old.
    Tune up?
  2. #2 Re: Replaced alternator, turning slow.
    GXP Level Member
    Mar 2015
    Tomball
    Are you aware that 04+ charging systems will vary between 15.5V-12.5V? If your system is not charging properly it could be due to the PCM or wiring may be to blame. If you put in a new alternator then it sounds like the problem is elsewhere.
    Jeff
  3. #3 Re: Replaced alternator, turning slow.
    SWPA
    If you unplugged the battery to replace the alt, as you should have, the ecu needs to relearn so things will be a little different for awhile.
  4. #4 Re: Replaced alternator, turning slow.
    Jul 2010
    Coquitlam,BC,Canada
    What is the voltage at start up? If 15.4v is after a few minutes or with no load, that is a bit high. Sounds like you may have killed the battery.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  5. #5 Re: Replaced alternator, turning slow.
    GXP Level Member
    Mar 2015
    Tomball
    It can actually be normal on an 04+
  6. #6 Re: Replaced alternator, turning slow.
    SWPA
    If my car shows 15.2 volts it will throw a charge system failure message. The GXP's on the other hand do run with a little higher voltage from what has been pointed out on this very forum.
    While driving if I monitor my voltage it usually runs 14.9 at the highest.
  7. #7 Re: Replaced alternator, turning slow.
    I Write E85 Stickies Frosty's Avatar
    Apr 2011
    South Dakota
    My 01 ranges from 15ish all the way down to 13 flat depending on the day. Usually in the summer it hits 14 for a couple minutes and then settles down to 13 flat after half an hour of runtime or so. In the winter on really cold days it hits 15+ and rarely drops below 14.
    "Lets just throw more boost at it and see what happens" -Frosty
    The Defacto Guide to tuning your car for E85. Read it and learn.
    I love Decker<3
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. car seems slow
    By jrb1027 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-23-2013, 10:41 PM
  3. 02 GTP Popping noise when turning at slow speeds. Intermediate shaft?
    By OcalaGTP in forum Brakes/Suspension/Chassis
    Last Post: 11-29-2012, 07:16 AM
  4. SLOW****
    By 2002 in forum Introductions/Noob Questions
    Last Post: 06-29-2012, 09:36 PM
  5. seems way to slow??
    By nicks98gtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-06-2011, 07:44 PM
