Thread: zzp pcm switch to overkill pcm disappointed
Results 1 to 20 of 40
  1. #1 zzp pcm switch to overkill pcm disappointed
    Feb 2015
    california
    I just switched from my zzp 1.0 tune to overkill pcm and i am getting same mpg a bit higher temps on coolant and transmission as well as 2 to 5 knock cruising... Much more knock than zzps tune... My car also sounds a bit funnier when first accelerating before boost. I already sent my zzp tune to overkill im a bit dissapointed and dont know what to do.
  2. #2 Re: zzp pcm switch to overkill pcm disappointed
    Kemmerer, Wyoming
    probably need to fix all the problems with your car before you start tuning it. higher coolant and transmission temps have nothing to do with the tune. and your car sounding funnier before boost could mean a million different things.
  3. #3 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2013
    37.295091, -121.930053
    wth your in ca like me and you CANT tune your car. you cant mod your car in any way period set it back and have a nice day. if you dont believe me go ask your local chp office
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2013
    here is the site that tells you what you CAN and CAN'T mod on any car in the state of Califorina
    http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
  5. #5 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2015
    california
    No problems other than more mpg with zzp pcm. Was told that zzp was **** compared to overkill. Ive got decent amount of mods.
  6. #6 Re: zzp pcm switch to overkill pcm disappointed
    Nov 2013
    United States
    If all you changed were the PCMs, weather and driving habits remained the same, the fan turn on/off settings might have gotten messed up causing an increase in temps.....
  7. #7 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2015
    california
    I smogged my car with zzp tune
  8. #8 Re: zzp pcm switch to overkill pcm disappointed
    Well they're two different tunes.. It's hard to say what ZZP did vs will to many factors unless you have the ability to open up. If you have KR it's time to further mod or figure out what's causing it.
    04 Comp G.
  9. #9 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2015
    california
    Ok guys i guess im not explaining myself well. I have a 02 gtp with these mods when i got zzp tune 180 tstat 3 inch catted downpipe ngk plugs msd wires borla catback k&n intake sd hood. After the pcm i got a powerlog and 3.5 pulley. Never got but maybe 1 knock at full boost on zzp. I know zzp has a very high fuel allowance switched to overkill hoping to update more acurately to the 3.5 pulley and maybe gain a mpg but keep knock low and now overkill is giving me 3 to 5 knock cruising?! Mpg stayed same and temps are higher. And car is making a different noise wasnt there before
  10. #10 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2015
    california
    Not sure what the kock could be. Wasnt this high with zzp tune and i was told overkill was better
  11. #11 Re: zzp pcm switch to overkill pcm disappointed
    GT Level Member Xorbex's Avatar
    Canada
    How high are the temps. A tune could affect those with pressure and fan settings. Get ahold of will and tell him whats going on im sure he would help. Any knock at WOT? Car will sound different as shift points are changed. If it sounds real funny then its probably not the tune and some other issue.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  12. #12 Re: zzp pcm switch to overkill pcm disappointed
    Switching tunes would have nothing to do with the car making a different noise.. Think about it and like I method two different tunes from two different companies.. ZZP method for KR tends to be add more fuel etc but there's way more to it.. Afr, timing etc plays a huge part.. I'm not exactly sure what your wanting from this thread.. Unless we can compare both bins in dhp or hpt we won't have much of a answer for u.
    04 Comp G.
  13. #13 Re: zzp pcm switch to overkill pcm disappointed
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Did you disconnect the battery for a while, and give the trims time to relearn after swapping PCM's? I could see you getting some extra KR, if you didn't clear the trims and give them time to relearn. Higher temps could be due to different fan turn on/off points, hard to say without seeing the bins.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  14. #14 Re: zzp pcm switch to overkill pcm disappointed
    Dec 2008
    Lawndale, CA
    lol my car passed smog with the mods in my sig and a tune. My brothers top swap passes smog as well.
  15. #15 Re: zzp pcm switch to overkill pcm disappointed
    Bastard Reptile's Avatar
    Kansas City, MO
    You normally don't have to do the battery disconnect to reset the trims, since they are normally wiped out on a full write.
    Different factors IN the tune can cause the trans temps to be higher, like shift times and TCC settings etc.
    The different noise you're hearing could be the IAC staying open, some settings cause this, and it could be annoying. If you're not happy with the PCM, contact Will, he's the only one that can do anything about it.
  16. #16 Re: zzp pcm switch to overkill pcm disappointed
    GT Level Member mguzzo's Avatar
    Buffalo NY
    he didn't say if he switched PCMs or flashed into the same box. i sure as hell hoped he disconnected the battery to put a new PCM in.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  17. #17 Re: zzp pcm switch to overkill pcm disappointed
    Quote Originally Posted by mguzzo View Post
    Bah.. you know how many I've done w/o disconnecting?
  18. #18 Re: zzp pcm switch to overkill pcm disappointed
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    yes he did in the first post.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  19. #19 Re: zzp pcm switch to overkill pcm disappointed
    Apr 2015
    Columbus, OH
    Pffft, you paint rotors. Your idol status just fell to like 9.5 with me today. That's still on a 5 scale, but please no more shockers today.
    Top Swapped 01 Imp
  20. #20 Re: zzp pcm switch to overkill pcm disappointed
    Dec 2014
    Maryland
    did Billbo just issue a new fatwa ? stop disconnecting the battery for a pcm swap ...
  1. Overkill pcm
    By rah575554eg in forum PCM Tuning
    Last Post: 08-20-2010, 09:29 AM
  2. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  3. DHP or Overkill PCM
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2009, 10:44 PM
  4. Trip to track very disappointed (vids)
    By Uno99 in forum Off Topic Discussion
    Last Post: 06-15-2009, 02:08 AM
