Thread: zzp pcm switch to overkill pcm disappointed
Page 2 of 2 FirstFirst 12
Results 21 to 40 of 40
  1. #21 Re: zzp pcm switch to overkill pcm disappointed
    Bastard Reptile's Avatar
    Kansas City, MO
    Bah.. you know how many I've done w/o disconnecting?
    Pshhh....You're not the only one.
  2. #22 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2015
    california
    I did not disconnect battery should i do a case learn or reconnect pcm with battery disconnected? Heres sime scans when trans temp is at 188 knock is 3 under acceleration ign adv is 35 to 20 idle cruising and 15 wot. Pulse width is 2 idle to 10 wot short trim is -3.9 idle to 5 wot long trim is 5.4 idle to 12 wot im afraid to wot at this temp the vehicle seems to run hard.
    Map psi -17 idle to 4 wot
    Map kpa 35 idle to 120 wot
    Maf lb 0.75 idle to 20.0 wot
    Maf freq 2500 idle to 8500 wot
  3. #23 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2015
    california
    Any input guys?
  4. #24 Re: zzp pcm switch to overkill pcm disappointed
    Apr 2015
    Columbus, OH
    Well, your running lean it seems. When exactly do you see knock? When cruising and not moving the throttle? Do you see it while cruising in 3rd or 4th only when you slowly roll on the throttle? Are you seeing it increase as you go WOT, or just a blip as you shift?
    Need to know when EXACTLY its happening. But anyways you really need to get that info to Overkill since he's the only one that can help you unless you can tune it yourself.
    Top Swapped 01 Imp
  5. #25 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2015
    california
    The knock rises with temperature of car knock at 3 when boosting at 180 trans temp and at 5 when just cruise controlling when trans temp is 200 plus. At that temp its pretty constant.
  6. #26 Re: zzp pcm switch to overkill pcm disappointed
    Contact Will...
    04 Comp G.
  7. #27 Re: zzp pcm switch to overkill pcm disappointed
    Apr 2015
    Columbus, OH
    So, you are driving down a flat road at say, 55 mph, and cruise control is on, you are showing a constant 5° KR? Only thing I can think is that the overkill tune ramped your cruise timing for better mpg, and your car is not liking it. Being lean doesn't help, but you are not so lean that it should matter under stock timing.
    Your options seem to be: 1 get in touch with OK, 2 get in touch with OK, 3 pulley up.
    Top Swapped 01 Imp
  8. #28 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2015
    california
    Quote Originally Posted by bandook View Post
    No on a decline i wont have knock mostly inclines and excelerating if trans temp is 200 ill get 3 to 5 knock
  9. #29 Re: zzp pcm switch to overkill pcm disappointed
    Apr 2015
    Columbus, OH
    Ok, it could be a tcc lockup issue, but I don't know what the point in this thread is really, since you don't have a tuner. You need to contact Will and get this info to him. He seems to be a reputable guy, and I'm sure he'll straighten you out. Let us know how it goes.
    Top Swapped 01 Imp
  10. #30 Re: zzp pcm switch to overkill pcm disappointed
    Jul 2011
    Robert, La./Pensacola, Fl.
    here is the site that tells you what you CAN and CAN'T mod on any car in the state of Califorina
    http://www.arb.ca.gov/msprog/aftermk...es/amquery.php
    That's why when I moved out of California years ago with the military, i never went back.
  11. #31 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2015
    california
    Just an update im pretty upset with Will he isnt replying to my emails much and hasnt called or answered an calls which is my preferred method. I have sent my zzp tune to him to I guess make it better? Not sure he will do that im in fear he will just make it worse.. Pretty much regretting getting a pcm from him. Shipping the pcm alone to canada is killing me if this second go around doesnt work im asking for a complete refund from him. Im taking a 5 hour trip in 100 degree weather tomorrow then 3 hr the next day and am in fear of damaging my car. I get up to 5 even 6 knock under acceleration on flat ground 50-70 mph before boosting...
  12. #32 Re: zzp pcm switch to overkill pcm disappointed
    go get a pcm out of a junk yard and use that till your tune is fixed.
    if your mod less that is. if your stock no tune will kill off the stock kr. it needs some flow mods, like a U bend delete at least. or a dp.
    headers really help, but ca is a douche state.
  13. #33 Re: zzp pcm switch to overkill pcm disappointed
    Feb 2015
    california
    Quote Originally Posted by ScottyDoggs View Post
    I have powerlog 3 inch dp 180 tstat kn intake msd wires ngk plugs 3.5 pulley
  14. #34 Re: zzp pcm switch to overkill pcm disappointed
    GXP Level Member
    Mar 2015
    Tomball
    Doesn't matter just drive it like a granny.
    Jeff
  15. #35 Re: zzp pcm switch to overkill pcm disappointed
    Quote Originally Posted by silenthaven View Post
    id still run a stock pcm waiting for the caned tune to come back.
  16. #36 Re: zzp pcm switch to overkill pcm disappointed
    Keep a stock pcm for situations like this when you have a issue with the current tune
    04 Comp G.
  17. #37 Re: zzp pcm switch to overkill pcm disappointed
    Kemmerer, Wyoming
    just buy the hp tuner, then you can learn how to screw it up yourself.
  18. #38 Re: zzp pcm switch to overkill pcm disappointed
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Wait so your just getting knock while crusing? Not at WOT?
    2012 F150 STX
    - Gonna be a race truck
  19. #39 Re: zzp pcm switch to overkill pcm disappointed
    Apr 2012
    Goderich, Ontario
    I really dout Will screwed up a tune.
    -Paul Walker
  20. #40 Re: zzp pcm switch to overkill pcm disappointed
    Apr 2015
    Columbus, OH
    Quote Originally Posted by SgtMarshal View Post
    lol
    Top Swapped 01 Imp
  1. Overkill pcm
    By rah575554eg in forum PCM Tuning
    Last Post: 08-20-2010, 09:29 AM
  2. Trans switch/ e brake switch
    By Halbs in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2010, 02:57 PM
  3. DHP or Overkill PCM
    By jacobmh27 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-06-2009, 10:44 PM
  4. Trip to track very disappointed (vids)
    By Uno99 in forum Off Topic Discussion
    Last Post: 06-15-2009, 02:08 AM
