Thread: Please Help Traction control ABS
Results 1 to 2 of 2
  1. #1 Please Help Traction control ABS
    Jul 2012
    Baltimore
    I have a 2005 GTP Comp G. Since it had 28k miles on it there has been a problem with the ABS light, Traction Control light coming on. It's been to the dealer MANY times and they usually replace a wheel speed sensor I believe numerous times on every wheel and it lasted no more than a few days. I'm sure this has come up with others and maybe covered here. Anyone?
    Thanks
  2. #2 Re: Please Help Traction control ABS
    Apr 2015
    Columbus, OH
    You need to have codes pulled when the light comes on. That will point you in the right direction. Could be wires. Look over all speed sensor wires and check for damage. You could pull the connectors off and clean them and grease them to see if it helps.
    But, yeah, codes will help.
    Top Swapped 01 Imp
  1. Traction control light only traction control
    By ccoimbre in forum General Grand Prix Discussion
    Last Post: 02-09-2014, 01:02 PM
  2. ABS and Traction Control not working but no ABS or Traction Control lights
    By jruether11 in forum Brakes/Suspension/Chassis
    Last Post: 02-22-2013, 04:40 AM
  3. Traction Control Off / Stability Control Off / Service ABS System
    By compro in forum Brakes/Suspension/Chassis
    Last Post: 12-21-2012, 09:37 AM
  4. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  5. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
