Thread: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
Results 1 to 20 of 37
  1. #1 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Jul 2015
    VA
    Hello,
    I used to have a 2007 Grand Prix V6, got totaled (act of god, topic for another day), bought the 2007 GP GXP about 4 years ago, 27 or 37k miles when I got it. Previous owner installed the Magnaflow CatBack exhaust and CAI branded cold air intake. When I got the car, it was throwing a misfire error - the plugs were fouled from AFM/DOD, which was corrected with new plugs. It started burning oil about 2 years ago (AFM / DOD related oil burning issue) - I had a shop do treatment on the rings (about the same process as in the service bulletin), and keep a couple quarts in the car and check it from time to time. It loses about a quart at about every 2000 miles. I get a lifter tap if the car sits for a while on a cold day, it pumps back up within a few minutes of starting it up. I go through about 2 front tires every year, rears every other year. I'm at 145k miles now.
    A couple years ago, I backed into a curb and crunched the downpipe, so it got the 3" Magnaflow downpipe (cheaper than OEM), the one that has a cheaper / more free flowing catalytic converter. Since the downpipe swap, I get a P0420 O2 sensor error if it idles at a light for a while, so I have an Actron reader (cut the locking tab to fit the OBDII connector more easily - it gets used a lot) in the center console I use to check and reset the check engine light. I'd love to get rid of that error since it kills remote start if we forget to reset it, but that's a minor issue.
    It got a TEP Street / Strip trans rebuild (sent mine in) at around 120k miles (last year) - the trans had started slipping / grinding. The TEP rebuilt transmission is THE best thing I've done for this car - much faster shifting, more firm shifting. It took about 2 or 3 months for the 1/2 shift to soften up, it was pretty aggressive at first. The rebuild has been very reliable, no problems or trouble with the rebuild. When the transmission was replaced, it got a new radiator for the TEP warranty, which brought the temps up, I've seen 220+, and it starts to slip at that high a temp. I ended up getting a trans cooler from TEP (inline with the radiator cooler) this year to remedy that, which has been another great addition - dropped my trans temp way back down, usually runs about 176 something. The trans cooler got installed when a trans line went bad - I did the one stock trans line and new cooler in the driveway, found that the trans line was run under the radiator hose which added a lot of tension and likely is what caused the line to fail, it was likely routed this way when the rebuilt transmission was installed.
    When the transmission was replaced, it got a new steering rack, I forget why - leaking, maybe. All was well and good, until this year.
    Right now, it has rack #3 in it (counting the one in it when I got the car), #4 will go in next week, and it has power steering pump #3 installed (first one was having a problem, second one had a problem, 3rd put in within the past couple weeks). It seems the rebuilt racks available just aren't very good - the last one, I think had debris in it - had a hard spot in one area, caused the pump to whine, the power steering would completely kick out at random.
    I took it in earlier this year because of excessive tire wear on the outside edge of the front left tire down to soft rubber (no odd wear on any other tires), and it was pulling to the left. Front struts, strut mounts, front and rear tires (they switched from the Potenzas to a different brand - I forget which, but they're harder and slip a lot faster, though they were supposed to be about the same, the Potenzas I was told weren't available for a few more months), and rack were replaced, tie rod ends seemed OK, the shop told me everything else seemed Ok. The pull continued, so I took it back - I've lost count of how many times it's gone back - 4, maybe 5, or more?
    About two weeks ago, the mechanic told me that they slotted some adjustment, something about 2 plates, one with a hole, the other with a slot, and that someone from GM told them that they slot the other one as a fix for W body cop cars (camber adjustment) - the steering seemed a little funny after that, can't quite explain, it feels like its mildly hunting for straight, though an alignment was done again. If I hit a really hard bump, it kind of wobbles really quickly (for less than a second, maybe a half second), then settles down. It does this weird thing if I cock the wheel left and gun it hard in reverse - the wheel starts to kick more left, seems to come from the front left, turning the wheel left. I've mentioned this to my local shop, but they didn't think much of it.
    Last week, I purchased new front wheel bearings, new outer tie rod ends, rear struts and mounts (rear struts were shot) - and they installed all but the rear struts and mounts. I get the call to pick up the car, with "good and bad news". I'm told the car was aligned, but there was a problem with TPMS, 10 pounds off, AND 3 warnings coming up on the dash, and a new rack was going to be ordered, AND the belt tensioner needs to be replaced, but the car is OK to drive, and shouldn't be pulling left. The car will go back next week for what hopefully will be the final trip in - I seriously doubt this is the end of all of this. They'll then install the rear struts, a new rack, and the belt tensioner (I ordered that this past Monday).
    Well, now it isn't ALWAYS pulling left, but it does pull left. Sometimes it leans right, but mostly still pulling left. The front left tire, replaced earlier this year, is showing the exact same wear pattern that caused me to take it in earlier this year, but I don't know how much of this is a result of wear while other things were tried - I guess I need to mark / measure the outer edge of the front left tire or something.
    For whatever reason, the shop almost always puts 40 PSI in the tires. I've told them several times, the thing needs 30 PSI, like it says on the frame of the passenger door. At 40, the transmission doesn't feel right, acceleration is off, and the handling is way off. So, when they told me the TPMS was off (I check my pressure fairly regularly, work where there's a lot of metal for tires to pick up), I had my doubts. I told them the TPMS may take several minutes to update. They told me that they put in 40 to do the alignment (something doesn't seem right to me when you set a tire at 40 to align and 30 to run, but then I'm not a mechanic). When I got it home, I checked the pressure all around - twice. Approx 40, 40 left side, 30, 30 right side - and TPMS agreed with a cheap gauge, within 2 PSI - so TPMS is fine, but I'm 10 pounds high on the left side. I'm so frustrated with the thing, I didn't even bother to change the pressure - maybe I can wear the middles and insides instead of the outside front left!! I almost don't want to drop the left ones down, as I am fairly certain it's going to pull harder left when I do.
    As for the alarms, I'm seeing 3 messages, stability, traction, steering - so I looked it up online, and found the speed sensor harness is a relatively common problem - opens and shorts can occur in the wiring. Magnasteer is disabled, the wheel is far more stiff than it should be. I called the shop and told them what I found (hey, I just want this thing FIXED, Guys!!), but they said they checked the coils and those were fine, and they could check further when I take it back, but they still were planning on replacing the rack - again.
    Just today, I noticed something else - I checked G's, and lateral G's was 0.00 - this was after driving a bit. Usually, I can lean my body left and right in the seat when parked and get 0.02 easily. So this is a new problem!! Not sure where the sensor is for lateral G's, if it has anything to do with the work they did the other day, etc - but it's definitely something that has changed since the last trip to the shop.
    The shop has been doing the right thing regarding cost - they aren't charging me for alignments - just the first one earlier this year. They aren't charging me for the racks, either - just for the difference in cost to a "dealer" rack (latest TWO racks, current and next). The belt tensioner was a surprise, though I know the pulley lip is chipped off, I think another shop did that - the local guys said it was leaking or something.
    I'm at about 80k miles on the current plugs and wires, and I'm getting a random shimmy in the engine at idle, though no misfire has been reported yet - I haven't even bothered mentioning that to the shop, I'll just do the plugs and wires myself at some point, I guess.
    When I got this car, I was in love. Lately, I get it back from the shop, lean on the throttle, and it just isn't fun anymore - the amount of money that's gone into this car in the past 4 years has just been sickening - I can't seem to get it out of any shop (I've had it at 3 different shops since I've owned it - a local trans shop that had no clue about this car, a tire shop, and my usual mechanics) for less than $1k. I've spent more than I owe on it. And lately, I can't look away from the road for more than a couple seconds before it starts to find a path OFF the road - like it's trying to commit suicide.
    I'm... Frustrated. At what point do I just throw in the towel, and buy... something else, something newer, something that isn't going to rack up $1k every time I take it in?? That's what I'm asking myself. Parts are difficult if not impossible to find - the Bilsteins are no longer made, so the ones in it (and the two boxed in the trunk) may be the last ones it sees, and, well, just about anything GXP-specific isn't going to be cheap (ex, $130 something for a belt tensioner).
    For now, the plan is:
    * Take it back next week.
    * They'll install the rear struts, strut mounts, belt tensioner, new rack (maybe, unless they find the speed sensor wiring to be a problem, then they may not).
    * One more alignment?
    If they come back with some other thing (at this point, I can't imagine what else that might be) that will cost me some ridiculous amount, I'll just haul it to a dealer and trade it in. Another $200 part would about finish me off, I think. It's hard to find something that I'd like as much as I used to like the GXP, though - something I'd be happy with. I've been thinking maybe a newer Buick Regal GS, 2014, 2015?
    When I get it back (barring no crazy parts replacements), if it's still wonky, pulling left, I'll take it to a GM dealer - I've lost faith in my local shop, and I'm desperate to get it right. My thought here is, just about all of the parts that can cause steering issues have been replaced (only thing I can think of is that the control arms / bushings are bad - wouldn't that be a laugh?? $40 something each!!), so there's no reason it shouldn't be able to be tamed back to where it should be.
    Beyond that, I've got hundreds of dollars worth of tires I don't like - but at least they'll last into next year. Plugs and wires need replacing. Then what? Bottom half engine rebuild when the rings finally gum up from DOD / AFM? I drive it over 300 miles a week, so disabling DOD isn't something I've seriously considered - I get about 21 MPG as it is!!
    Any thoughts on the steering issue? At times I think maybe I'm just being picky, but the wear says otherwise. I've dealt with my local guys for nearly 10 years now, and they've been fair in the past. Last year, the alignment they did was perfect, but this year, well... And is there any way to tune out / fake out the P0420 sensor error?
    I may have missed something, if so, just ask.
    Thanks
  2. #2 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    how about you sum up what wrong in like a paragraph? im not reading that wall.
  3. #3 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Find a new mechanic and/or work on the car yourself.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  4. #4 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Delaware County, PA
    I have heard for years that these cars eat money. I still wanted one but couldn't pull the trigger. You have found this out the hard way. Tires and transmissions seem to be the universal problem. I can't speak for the codes or alignment issues. I would have turned off the AFM as I was leaving the dealer; the mpg isn't worth the sticking rings/oil consumption problems. Surprised to hear your Bilstein struts didn't hold up. My GT eats front wheel bearings about every 6 to 9 months. Your GXP may have demons.
    I sat in a Regal when my car was at the dealer a few months ago - hit my head getting in and out. A Lacrosse with the 3.6 (300 hp) would be a better fit for you and they are plentiful should you decide to bail. The 2013+ Buicks are certified for 6 years, 100,000 miles - give you something of a breather.
  5. #5 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Enfield, CT
    Quote Originally Posted by ScottyDoggs View Post
    Dude he's not being brief which is a relief on this forum. He's elaborating every detail to narrow down the problem. Give him a break lol.
    I'm at work so I'll look it over again and try to help you out.
    BTW, good grammar. Some people who ask for help on here can't properly construct sentences for ****.
    Sent from my LG G3
  6. #6 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Arizona
    Have you ever replaced the lower mounts ? And if the slotted the strut out there was no reason to since your at factory height. So somebody ****ed up your strut mounts or something in that area. Quit paying for more racks and pumps. And make these people do you right. Complete bull****
    Besides the Trans going out which a minority of that is due to dod and horrible factory programming the gxp last as long as any other and has the same issues any other woody has
  7. #7 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Quote Originally Posted by 91parkave View Post
    I still don't know why you keep preaching that...
    These things turn magma style temps, easily. I've talked to Dave on mulitple occasions about these LS4 cars and they eat transmissions 100 ways from Sunday more than the 3800 cars. The heat being the main killer. I ran slicks and beat the ever living god out of all my 3800 cars with no transmission problems to date a decade later, albeit a sheared diff from running slicks, which ended up being a freak thing.
    This GXP I picked up had 50k~ on it, and lost the trans a few thousand miles later. It also had a tune. And a cooler. That's what 225*+ temps will do.
  8. #8 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Arizona
    it the amount of owner neglect about Trans temps the absolutely horrible factory programming in conjuction with dod being a huge culprit that would kill any transmission. And build dumb amounts of heat. But most people won't pay attention till it's too late.
  9. #9 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Jul 2015
    VA
    ScottyDogs - This isn't my first rodeo - I've been on a number of forums over the years, admin on a few, mod on a few, etc - and I've seen thousands of single paragraph posts that tick people off - so I try not to do that when I post. You know, I don't actually recall anyone being put off by a newbie's first post that was too lengthy!!
    Still, I'll entertain a single paragraph, newbie style:
    I am a N00B!! My car is broken. Please help me!! I am not a mechanic, but I can follow directions if u can help. Would be kewl if u could stop by and fix it 4 me, I live in BFE. It pulls left. 4 Racks, 3 Pumps, now I get 3 err, lat G is broke, steering is stiff and acting funny. I get a CEL I have to reset regularly, too. It's my DD. Spending money sux! that's what wrong.
    Not enough spelling errors, punctuation is too proper, but it's got that newbie twinge, no? Done teasing, seriously.
    buck531 - Working on it myself is something I've considered - many times. I've been meaning to buy a beater (and could have a few times over for what I've paid in repairs) so I can garage and work on the GXP, but I've been drowning in repairs.
    SpringfieldGT - Definitely not cheap. I expected the transmission problem - I read up around the 'net and new it was coming. The Bilsteins in the front lasted 140k something miles, not sure how that ranks. The rears, about the same, but I've been putting them off until they were ordered and delivered last week. It slumps when I put in a tank of gas (didn't do this in the past), and has some bounce in the rear, so I think the shop is right that they're shot.
    I've thought about disabling AFM, then I'm a few more thousand miles down the road. I wonder if my local shop can turn it off, just to see what the MPG would be - it's around 21 MPG 90% interstate driving with no traffic. I've been thinking of getting another LS4 that I could work on, something I could keep ready for a swap, buying tools as I go, etc.
    If I remember right, this is the first set of front wheel bearings to go in since I've had it.
    Regal - I like the newer ones from what I've seen, haven't sat in one yet - but if I like it, I may sack the GXP sooner than later!! Lacrosse may be an option. Buick seems to be about the most comparable thing to Pontiac from what I've seen.
    HighOctaneRacing - Thanks, I do try!!
    91parkave - Lower mounts - do you mean the lower control arms? No, but that's one of the few things that hasn't been replaced, one I think may be a cuplrit.
    In looking up what you're referring to, I was reminded of another problem, a loud screeching / scraping noise I get just when starting, happens maybe once a month. I need to check into that one a little more.
    I had read about the trans problems, and I generally take it easy on the trans - my original one lasted to 120k. I usually ease up on the throttle at the shift points, and I rarely use TapShift and beat on it. Dave at TEP said it was really clean when he tore it apart, said usually they're tore up with lots of debris - which made me glad I sent mine in instead of swapping.
    In all fairness, I'm not paying for more than the 1st pump and the 1st rack purchased over a year ago now, and more recently the price difference of dealer rack minus the cost of the 1st rack - and they're not charging me labor on the pumps or the racks beyond the first replacement. Heck, they gave me my car back last time without charging me a dime (admittedly, they'll charge me for the work the other day on the next bill), and I paid < $90 for the 1st pump with labor, which seemed plenty fair. I've only paid for one alignment, but I think they've done 4 or 5 at this point. I'm not here to slam my local shop (I won't even name them here), but I realize this car is something they're not completely familiar with. I'm just looking for answers and options.
    blueguy - I noticed trans slip at just over 200 degrees on the original trans, no cooler. I checked my temp on the way home today, 150 something degrees (!!) after 15 miles, running 78 mph down the interstate, 80 something outside. The TEP cooler I put in made a HUGE difference. In the past, it would be 170, 180 at that point in my drive.
    Something I was wondering... As I understand it, Stabilitrak uses the yaw sensor under the center console (is this used for Lat G on the DIC?) and the steering wheel position sensor to decide how to apply braking - what would happen if the steering position sensor was off a bit, would it apply light brake to a wheel, or would it pulse in a way that could be felt? Does it only kick in for hard cornering, or is it more subtle? The shop guys said the caliper doesn't appear to be sticking.
    I did manage to register a lateral G value yesterday, it was 0.05 - not even close to legit. Would a short in the wheel speed sensor harness interfere with the sensor that drives this value?
    I'll get under the car this weekend and check the speed sensor harness wiring with a meter.
    What is in the rack for Magnasteer, is it just the coil that controls the hydraulic fluid flow, or is there more than that?
    Thanks!!
  10. #10 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Arizona
    That's all it is for the rack. And yea I don't see your yaw sensor physically being bad, my guess is somewhere you got a short. It's gonna take some digging. And with all the work that has been performed and amount of electrical connections having to be moved arouND. No telling where it could actually be
  11. #11 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    I may have missed something in reading your posts, but have you made sure the cradle is properly aligned in the car? That is the first thing that should be done before any other alignment work is done, especially what your mechanic did.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  12. #12 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Jul 2015
    VA
    91parkave - Yeah, I'm thinking the same - electrical problem. I was researching, and I've found plenty of ABS-related problems that coincide with my other two errors, but I'm not getting an ABS error - so that makes me think short. I just walked back in from looking under the hood. I have a wire routed over the trans linkage, that just isn't right, it'll wear through the conduit at some point, I'll relocate it.
    More interestingly, I found a connector - and I have no clue where it was intended to go. It's close to the ABS module, runs back into the harness over the top of the transmission, this same harness connects to the ABS module. This connector is pointed towards the firewall, but I see nowhere for it to go. It looks clean - like it's been disconnected for a short period of time kind of clean. Before I go any further, I want to make sure this isn't related.
    LeadfootCJ7 - I don't know if they aligned the cradle at the shop - how is that done? The guys at the shop never mentioned aligning the cradle, but they may have. I'll bring it up when I take it in later this coming week.
    So, check out the pic - What connector is this (left), and where should it be going? This is looking down at the transmission by the ABS module. The wire was laying on the transmission next to another wire headed towards the firewall (up in the pic). And what is that other wire, running back with this one? It is laying on the control lever for the transmission, a connector attached is just out of view towards the top in the pic, I think it has 5 wires.
    Edit: I was just looking at the steering column diagram, and am wondering - is this connected to the steering wheel position sensor harness?? Going to go look around some more.
    More info: The latest replacement steering rack is leaking - I was told it might be, that they weren't positive, but it is. I relocated the other wire to under the control linkage on the transmission - there's a plastic mount around the cable towards the firewall side of the transmission, and I see where it should go, but it's inaccessible from the top. Still, it's better under the linkage than over. I still haven't found where that connector goes.
    2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long... Attached Images
  13. #13 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Oct 2012
    Houston, TX
    There are slots in the cradle on the passenger side near the bolts to align in. The front one is oval and the rear is round.
  14. #14 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Arizona
    All you need is a half inch extention to stick in the holes as you tighten the cradle bolts it'll be perfect every time that connector could be your magna steer connector if it leads to the driver side, there should be a Har essential on the steering rack for it to connect too
  15. #15 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Mar 2015
    Tampa, FL
    get whatever you need replaced fresh to start and find a shop that does race car alignment, you want someone that does speciality alignments and is going to look beyond if its in the green on the rack monitor. Where I live there is a few places that specialize in it, but you pay for it, usually twice the price of what a normal tire place will charge.
  16. #16 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Jul 2015
    VA
    LeadfootCJ7 - Thanks, I'll mention it to them when I stop by this week.
    91parkave - Sounds easy enough. Magnasteer - well, THAT makes sense (errors on DIC). I wonder if the latest rack is the non-Magnasteer one.
    mars5l - It'll be a challenge to find a place, I'm about an hour and a half from the nearest city. Nice winding roads with little traffic, but at a price. I'll have to do some research and see if I can find a good place to take it.
    I stopped by the shop yesterday, but they were already closed. I'll try again today. I really hope this is the last trip in, but if it still pulls left, I'll take it somewhere else - these guys have tried and tried, and I really don't see a point taking it back again if it pulls left when I get it back. I've given up on them fixing the pull, I just want the rest sorted out, then I'll take it to another shop for the pull.
  17. #17 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Mar 2015
    Tampa, FL
    they gave you a printout from your last alignment? Is it always pulling or on certain roads it pulls?
  18. #18 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Enfield, CT
    Some alignments shops set the car up for road crown. Might wanna look into that.
    Sent from my LG G3
  19. #19 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Jul 2015
    VA
    mars5l - Yes, they did (they always do), but I may have thrown out the last one (I've lost faith in that paper!) - I can try to find it (or another recent one?) if you're interested. On the 2nd or 3rd alignment this year, they pulled the alignment from last year to show me where it was then and what it is now (to show me that the machine said it was more or less the same) - and last year, the alignment was the best it had ever been.
    HighOctaneRacing - Yeah, I talked to them about how it's pulling, what conditions, which roads, which turns (I drive the interstate by their shop), many times - and at first, they suggested that the road I was on was what was causing the pull, leaning left on the left side, right on the right side - but on a road leaning right, it still pulls left!! It pulls way left on the left lane of a two lane road. If the road is canted severely enough to the right, it WILL go straight!!
    At one point, they told me they found some bad ceramic bearings in their alignment rig, and even after replacing those and doing another alignment, same results. Meanwhile, the tire tread wear is pretty bad on the outside front left right now, the profile of the edge of the tread is getting worn down (4 new tires this year when I took it in for this specific issue, so two different tires on the front left, even different brands, wearing on the same edge). At this rate, the tire will be toast in another 3 or 4 months!!
    At lower speeds (most of my driving is 62 mph+), around 35 or so, on a straight road that is leaning slightly right for a stretch with no bumps, I can push the wheel right to where the car just nudges right, let go, and it will go straight until I hit a slight bump (any tire, either side), then it pulls left, and will end up on the other side of the road in 6 or so car lengths - and once it gets to the middle of the road, the left pull fully takes over.
    Is it better than it was when we first took it in this year? Yes, there was an improvement (it was pulling more) - right after the first alignment this year, the drive home and the first drive to work, it was quite a bit better - but still pulling left. It seemed to get worse (up to a point, then it stayed at that level) the more it was driven, and it hasn't been that good since. I've wondered if I'm shifting something around by how I drive.
    Whenever the car goes into the shop for more than a half a day, I get a rental car. I've driven a few different rental cars this year on the exact same roads I drive the GXP on. ALL of these cars have alignments that are just fine. Ok, well, one was slightly dodgy, like the toe was a little off, but not nearly as bad as the GXP. It's irritating to drive a cheap-and-abused rental that tracks straight, then get the GXP back from the shop, "It's fixed!!", still pulling left. I almost look forward to getting a rental - that's just sad!!
    I talked to the guys at the shop yesterday, and Tuesday is the next (last, if all that's wrong is the steering pull!!) trip to my usual shop for the steering pull - I'm willing to do a road trip to a shop that can set it straight. Anyone have any suggestions for a shop in Richmond, VA? Anyone at a shop in Richmond, VA want to take this on, solve it, finish it? Anyone have a GXP with a solid front end I can transplant??? (kidding on the last one)
  20. #20 Re: 2007 GP GXP Money Pit - Steering Pull, DIC Errors, Etc - Very Long...
    Enfield, CT
    At this point I would get on the internet and try to find a very very good steering and suspension specialist.
    Sent from my LG G3
  1. electrical errors please help
    By dgjks6 in forum General Tech Discussion
    Last Post: 02-26-2014, 10:02 PM
  2. server errors
    By Scottydoggs in forum Forum Bugs/Suggestions
    Last Post: 11-20-2012, 08:59 AM
  3. 2007 Grand Prix GXP Steering Box
    By WkDcLwNz in forum General Grand Prix Discussion
    Last Post: 11-12-2012, 02:12 PM
  4. Certificate errors. Multiple browsers
    By Mad Monkey in forum Forum Bugs/Suggestions
    Last Post: 10-25-2012, 06:32 AM
  5. Power steering pump line too long?
    By copgtp in forum General Tech Discussion
    Last Post: 02-03-2012, 04:05 PM
