Thread: egr valve ??
Results 1 to 8 of 8
  1. #1 egr valve ??
    Jan 2015
    illinois
    recently my check engine lite came on the code was the egr . autozone wanted 160 for the egr ibougt one online ebay for 35 site said it was for 99 gtp and alot of 3800 models . when it arrived i noticed the inlet or outlet was smaller by a little bit installed it anyway it was egv466t. lite came back on pretty quick. already sent it back tha tmay be a mistake .what egr valve do i need dont want to spend 160 if i can get one for 35
    any help is greatly appreciated
  2. #2 Re: egr valve ??
    Feb 2013
    37.295091, -121.930053
    well you can get the egr block off plate and get it tuned so the code wont set
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: egr valve ??
    Bastard Reptile's Avatar
    Kansas City, MO
    I've got a complete one, bracket, tubes and all that should fit that car.
  4. #4 Re: egr valve ??
    Mar 2014
    Tucson
    Did you confirm the old EGR was bad, and the code wasn't tripped for some other reason?
  5. #5 Re: egr valve ??
    Jan 2015
    illinois
    is there a way to check the egr ? after i put the original egr back on the first couple times i started the car it kinda rattled a bit i assume it was the egr. i am working on starting some upgrades but this is first . i bought an obd2 reader that links to a smartphone so i could check for kr but as i tried to find that setting going by alphabetical order in the k's it only had a setting for kilometers nothing bout kr
  6. #6 Re: egr valve ??
    Mar 2014
    Tucson
    I mean... It's most likely the egr is bad, but it's not the only possibility:
    http://www.obd-codes.com/p0401
    http://www.gearchatter.com/viewtopic9016.php
    Carbon and faulty MAP sensor are also possibilities. FWIW, Amazon says the valve you were shipped (EGV466T) is a direct replacement. I guess that's why, when you said the code came back, I wasn't convinced it was a faulty valve.
  7. #7 Re: egr valve ??
    GTX Level Member EJOUIE's Avatar
    Newnan, GA
    Try cleaning the original. Take a small (tiny) flat head screwdriver and scrape off as much of the black you can. Be sure that the valve can move up and down freely. Drowning it in carb cleaner after you done all you can with the screwdriver is also a good idea. I just did mine this morning and it fixed my issue. My car is a 97 with 162,000 miles on it and that EGR is stock.
    97 GT white 4 door-SOLD
    Cherry 2005 Impala LS- Front and Rear GMPP Strut Tower Braces
  8. #8 Re: egr valve ??
    Skip cleaning..
    Google the code. If it's for flow.. then you are barking up the wrong tree based on the name of the code having "EGR" in it. Cars aren't quite to the point where it tells you the exact part to swap.
    Kinda like when someone chips a piston and sees a ton of knock. That doesn't mean the knock sensor is bad, it means you are engine swapping.
  1. aluminium valve covers, 90 lb ls6 valve springs for sale
    By SgtMarshal in forum For Sale - Parts
    Last Post: 09-04-2014, 04:30 PM
  2. Stock intake valve versus 1.9 intake valve...worth it?!
    By slimguns in forum General Tech Discussion
    Last Post: 03-30-2013, 05:18 PM
  3. Replies: 26
    Last Post: 08-30-2012, 04:50 PM
  4. EGR valve
    By cobra8432 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-23-2011, 11:12 PM
