Thread: Engine derped really hard. Tryna find out what's wrong.
Results 21 to 40 of 46
  1. #21 Re: Engine derped really hard. Tryna find out what's wrong.
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    I actually got a 4x4 4.0 '91 Cherokee off CL for $500, owner said it had a bad engine, was knocking pretty loud. Got it home, did some troubleshooting and found the crank pulley was bad (separated from the rubber, no noise with belt off), swapped it out and drove it to work for a while. Eventually sold it to my mother in law, who finished it off in a year or 2, with almost 250k on it.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  2. #22 Re: Engine derped really hard. Tryna find out what's wrong.
    Quote Originally Posted by J57ltr View Post
    But why did you tear the top end off when the sound was coming from the bottom?
    Jeff
    x2?
  3. #23 Re: Engine derped really hard. Tryna find out what's wrong.
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    Wonder if the starter was hanging up?
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  4. #24 Re: Engine derped really hard. Tryna find out what's wrong.
    we need a mod to change the title of this thread.
    it should be,
    owner derps out and fails even try to investigate bad sounds, then tears the engine down. and now what?
  5. #25 Re: Engine derped really hard. Tryna find out what's wrong.
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by ScottyDoggs View Post
    it should be,
    owner derps out and fails even try to investigate bad sounds, then tears the engine down but actually tears it down two days later after some some suggestions are given. and now what?
    Fixed that for you.
  6. #26 Re: Engine derped really hard. Tryna find out what's wrong.
    that works too. he was all to eager to rip his engine apart if you ask me.
    lets hope he can put it all back together again lol
    at this point a used engine maybe in order.....
  7. #27 Re: Engine derped really hard. Tryna find out what's wrong.
    GXP Level Member
    Mar 2015
    Tomball
    Here I am fighting tooth and nail trying to keep my heads on and this guy just chunks them off like a Coed during Mardi Gras looking for beads
  8. #28 Re: Engine derped really hard. Tryna find out what's wrong.
    your killing me. so true tho.....lmao!
    maybe hes not heard they rarely blow head gaskets?
    got to admire his enthusiasm tho. dove right the f in blind as a bat lol
  9. #29 Re: Engine derped really hard. Tryna find out what's wrong.
    GXP Level Member
    Mar 2015
    Tomball
    I wonder if there's going to be a huge part out after he realizes it's going to cost him about $300 just to get them heads back on only to find out it was the tensioner all along.
  10. #30 Re: Engine derped really hard. Tryna find out what's wrong.
    nah, head gaskets and new bolts under 60, lim gaskets another 40 or so. then fluids.
    full gasket kits to do the whole engine and new fluids and elbows ran me just over 200 bucks.
  11. #31 Re: Engine derped really hard. Tryna find out what's wrong.
    GXP Level Member
    Mar 2015
    Tomball
    You don't surface the heads?
  12. #32 Re: Engine derped really hard. Tryna find out what's wrong.
    Cibolo, TX
    Yeah I wouldn't bolt on a set of heads without at least a resurface, guides inspected, new seals, and 3 angle valve job. Probably new springs too while I had it all apart and doing seals anyways.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  13. #33 Re: Engine derped really hard. Tryna find out what's wrong.
    they looked good with a metal straight edge, they came off a running jy engine. last owner took them off to use his heads he had already. so they got cleaned up and bolted back on. 500 miles later shes still tight and running well.
    i did lightly port em, new seals, and lapped the valves too.
  14. #34 Re: Engine derped really hard. Tryna find out what's wrong.
    I pulled the 181k mile heads off my black gtp, stored them in my shed for about a year, then slapped them on a l26 and ran them for 30k miles and had no issues.
    Sent from A Galaxy Far Far Away
  15. #35 Re: Engine derped really hard. Tryna find out what's wrong.
    Sep 2014
    Worcester, MA
    I had a non-Pontiac engine make similar sounds (as you describe them anyhow) and it was the timing chain jumping a tooth. Kinda uncommon though.
  16. #36 Re: Engine derped really hard. Tryna find out what's wrong.
    GXP Level Member
    Mar 2015
    Tomball
    Quote Originally Posted by Slick2500 View Post
    Now that is pure luck, but it's dry enough where you are at that the heads won't rust solid in that time. Here if you have exposed steel it will start to rust before you can get primer on it.
    Bobc455,
    How, with what I would assume was a worn out timing set and have it jump full retard by a tooth still manage to keep the engine running?
    Jeff
  17. #37 Re: Engine derped really hard. Tryna find out what's wrong.
    GT Level Member TheDarkAngel's Avatar
    Oct 2013
    Iowa
    As the car is going to get a top swap, the heads needed to come off anyways, and this was a good reason to get them off. I plan to pull the block out, take the front and rear covers off, and the pan next week, which should tell me what actually happened.
    First car- 1999 Buick Regal LS (Sold)
    Current ride- 2000 Grand Prix GT (The Dark Angel) DIY Intake, flipped bushings, visual stuffs, lowered on Eibachs, Topswap loading...........
  18. #38 Re: Engine derped really hard. Tryna find out what's wrong.
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    when my ac went to crap it made god aweful noises. at first a thought it was the supercharger coupler. sometimes it rattled and sounded like rocks in a can , sometimes it made a grinding noise. then i seen the metal shavings on the ac pulley , so i yanked the compressor and put in an ac pulley delete...no more noise.
    2000 GTP - 3" Catted DP...ZZP Plog...9" Cone filter...Reptile pcm...3.4 pulley...AL104's
  19. #39 Re: Engine derped really hard. Tryna find out what's wrong.
    well now you can just look for a sc engine instead of a true top swap. if you cant find one get the new n/a block.
  20. #40 Re: Engine derped really hard. Tryna find out what's wrong.
    Oct 2013
    Iowa
    I plan to go N/A with a top swap anyways, I have a PCM from intense with a custom tune on it.
  1. Its hard to find a good shop!!!!
    By dmack976 in forum The Rant Forum
    Last Post: 03-04-2015, 08:11 PM
  2. Replies: 0
    Last Post: 11-04-2014, 10:32 AM
  3. Lost all shifts but tryna figure out what it could be
    By jayroca in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-02-2014, 09:46 AM
  4. Tryna open my car hood and im locked out of my car
    By jayroca in forum General Tech Discussion
    Last Post: 06-22-2014, 09:49 AM
  5. For all your hard to find car part needs!
    By Reptile in forum Off Topic Discussion
    Last Post: 05-09-2008, 09:13 AM
