Thread: Engine derped really hard. Tryna find out what's wrong.
Page 1 of 3 123 LastLast
Results 1 to 20 of 46
  1. #1 Engine derped really hard. Tryna find out what's wrong.
    GT Level Member TheDarkAngel's Avatar
    Oct 2013
    Iowa
    So one day near the end of a 25 mile trip home, then engine dropped power, and started to sound like unholy things, including death. Even with it sounding as horrible as it did, I was able to get it home, and beyond the noise, it drove fine. I'm trying to figure out what might be wrong, so I know if I need a new short block or not, but one thing I think may have happened is the timing chain may have broken? It sounded like something was bouncing around low
    down, so maybe that could be the cause? I have it down to the heads, and the plugs out, but the valves are all straight, no rockers are broken, and the plugs looked perfect. Anyone have any input?
    First car- 1999 Buick Regal LS (Sold)
    Current ride- 2000 Grand Prix GT (The Dark Angel) DIY Intake, flipped bushings, visual stuffs, lowered on Eibachs, Topswap loading...........
  2. #2 Re: Engine derped really hard. Tryna find out what's wrong.
    should have posted a vid before you tore it down. now its a total guess.
    unless you took a few?
  3. #3 Re: Engine derped really hard. Tryna find out what's wrong.
    Oct 2013
    Iowa
    I didn't get any videos of it, but it sounded like something was bouncing around, and the belt was squealing off and on, which hadn't happened before. Doesn't sound like a knock at all.
  4. #4 Re: Engine derped really hard. Tryna find out what's wrong.
    no idea with out hearing it run, so you may as well get a new bottom end if you found nothing wrong with the heads.
  5. #5 Re: Engine derped really hard. Tryna find out what's wrong.
    Oct 2013
    Iowa
    Great ��
  6. #6 Re: Engine derped really hard. Tryna find out what's wrong.
    Oct 2013
    Iowa
    Know anyone getting rid of a short block?
  7. #7 Re: Engine derped really hard. Tryna find out what's wrong.
    GXP Level Member
    Mar 2015
    Tomball
    You need to Herp it a little more. So describe the noise besides "death" and "horrible" use better descriptors. Knocking, Clunking, Ticking are all acceptable. If the timing chain broke or skipped a tooth the engine would not run......at all. Maybe the tensioner for the timing chain is going out. But why did you tear the top end off when the sound was coming from the bottom? It's a little late but invest in a mechanics stethoscope it will help you pinpoint problems in the future.
    Jeff
  8. #8 Re: Engine derped really hard. Tryna find out what's wrong.
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    pull the oil pan, report back what you find the bottom.
  9. #9 Re: Engine derped really hard. Tryna find out what's wrong.
    Oct 2013
    Iowa
    I plan to take the engine out either tomorrow or Saturday, so I'll know for sure then, and it was mostly a clunking found, but like something was knocking around a cylinder.
  10. #10 Re: Engine derped really hard. Tryna find out what's wrong.
    Quote Originally Posted by TheDarkAngel View Post
    i got the last one i know of. ( your a long way from NJ too) junk yards and cl is where you need to start tho.
  11. #11 Re: Engine derped really hard. Tryna find out what's wrong.
    Oct 2013
    Iowa
    There's a wrench n go an hour and a half from here, so I might try that this weekend, and other than that, engines hover around $400 on Craigslist.
  12. #12 Re: Engine derped really hard. Tryna find out what's wrong.
    thats fair for a l67. if you can only get a n/a engine only, you can always top swap it with your old parts.
  13. #13 Re: Engine derped really hard. Tryna find out what's wrong.
    Oct 2013
    Iowa
    Well it was N/A to start, and that's the price for another N/A. But I have the parts to top swap.
  14. #14 Re: Engine derped really hard. Tryna find out what's wrong.
    St. Louis
    Does the A/C compressor spin freely? I've seen them lock up and cause all sorts of strange things, including belt squeal. If you have the heads off how do the tops of the pistons look? Any chips/missing pistons?
  15. #15 Re: Engine derped really hard. Tryna find out what's wrong.
    GXP Level Member
    Mar 2015
    Tomball
    Check the dampner had one make me think the engine was toast.
    Jeff
  16. #16 Re: Engine derped really hard. Tryna find out what's wrong.
    Oct 2013
    Iowa
    The heads came off today, and both the heads, and the pistons were perfect. No scoring in the cylinders, and no metal on the drain plug either. Would it be something to do with the timing chain or tensioner?
  17. #17 Re: Engine derped really hard. Tryna find out what's wrong.
    GXP Level Member
    Mar 2015
    Tomball
    Well that might have been mentioned before.
  18. #18 Re: Engine derped really hard. Tryna find out what's wrong.
    hangover park IL
    Sounds like the ac compressor clutch and bearing are a likely possibility. ...but I'm going to guess that you did not go through proper diagnostics and check with the belts off.
    ~James~ Psychotic Gearhead
  19. #19 Re: Engine derped really hard. Tryna find out what's wrong.
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    The first thing I'd have done was pull the belts, not the heads. If it still makes "unholy sounds" without the belts, then you might have an engine problem.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  20. #20 Re: Engine derped really hard. Tryna find out what's wrong.
    GXP Level Member
    Mar 2015
    Tomball
    When the dampner went on my PA it sounded like a rod knocking but it was a back and forth sound like a coupler was broken and it didn't wasn't supercharged.
    Jeff
  1. Its hard to find a good shop!!!!
    By dmack976 in forum The Rant Forum
    Last Post: 03-04-2015, 08:11 PM
  2. Replies: 0
    Last Post: 11-04-2014, 10:32 AM
  3. Lost all shifts but tryna figure out what it could be
    By jayroca in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-02-2014, 09:46 AM
  4. Tryna open my car hood and im locked out of my car
    By jayroca in forum General Tech Discussion
    Last Post: 06-22-2014, 09:49 AM
  5. For all your hard to find car part needs!
    By Reptile in forum Off Topic Discussion
    Last Post: 05-09-2008, 09:13 AM
