Thread: Engine help
Page 2 of 8 FirstFirst 1234 ... LastLast
Results 21 to 40 of 142
  1. #21 Re: Engine help
    Quote Originally Posted by valente View Post
    Fine, I will tell you how I broke it
    I was trying to separate the engine and trans, but had forgotten to take the 3 bolts off the torque converter
    I was working outside and it was about 90 degrees and I was tired
    Junk yard it is then
    that blows. it was hot as hell the two day i was ripping and replacing over. at least i was out of the sun in a garage, but it was still hot as balls.
    if your heads are ok dont touch the heads, i only did them cause i top swapped a n/a block. had no choice in the matter.
    i'd do the lower conversion kit. a lim gasket kit, upper plenum gasket and new valve cover gaskets. new coolant, oil and a filter.
  2. #22 Re: Engine help
    MINNESOTA
    Thanks
  3. #23 Re: Engine help
    MINNESOTA
    For the valve cover gaskets can I get the ACDELCO Part # 24503937
    Cant seem to find the lim gasket kit
  4. #24 Re: Engine help
    search this on rock auto. MAGNUM Part # MS18144 lim stands for lower intake gaskets. iirc it came with the side cover gasket on the lim, the t stat rubber ring and gasket rtv metal lim gasket and the rubber sides.
  5. #25 Re: Engine help
    FEL-PRO Part # CS9917
    FEL-PRO Part # MS95744
    FEL-PRO Part # VS50465R
    this is everything i used. minus the head gaskets.
  6. #26 Re: Engine help
    MINNESOTA
    Thank you
  7. #27 Re: Engine help
    MINNESOTA
    Quote Originally Posted by ScottyDoggs View Post
    Does it matter I you have a s/c
  8. #28 Re: Engine help
    as per billboost, it may be wise to not change the seal in the timing cover if its not leaking. i changed mine, then i found a groove on my balancer and it leaked, i repaired the balancer with a sleeve, and it still leaked, then i found the seal damaged so i went and replaced the seal and thats no fun in the car.
  9. #29 Re: Engine help
    your n/a? then you need different valve cover gaskets, and the upper intake gasket is different.
    while you have the lim off its a good idea to mod it, seal the coolant holes and hog out the side cover water jacket.
    http://www.grandprixforums.net/threa...w-to-Mod-a-LIM
  10. #30 Re: Engine help
    MINNESOTA
    Ok, I think I found the same parts you bought.
    But with different part#s
  11. #31 Re: Engine help
    some how i thought you had a supercharger.
  12. #32 Re: Engine help
    MINNESOTA
    My car is a 2005 COMP G
  13. #33 Re: Engine help
    oh, so it is sc'ed. you can reuse your super charger gasket if its the metal kind. if not you need to buy one and those are like 40 bucks. and everything else should fit.lim, valve covers. lower kit , only you wont use the pan gasket for a al pan it gets rtv only.
  14. #34 Re: Engine help
    MINNESOTA
    Ok, please don't get frustrated if it seems that I keep asking the same questions
    Just trying to do this the right way
    When you say everything should fit, are you talking about the part# you posted with the pics.
    I tried searching the part# and it said no searches found
    This are the parts I found
    Part # B38CSA
    FEL-PRO Part # MS96789
    FEL-PRO Part # TOS18717
  15. #35 Re: Engine help
    search your year car, then for a lower conversion gasket kit, lower intake gaskets, valve cover gaskets with grommets and upper plenum gasket.
  16. #36 Re: Engine help
    MINNESOTA
    Got it
    Thanks
  17. #37 Re: Engine help
    Looks like this might be the first time yanking this engine out. Good job.
    You can actually get the diff to engine bracket through the wheel well or by reaching down over the motor from the top. Heck..you can get the backwards bolt by doing that and then using a 12" extension under the exhaust manifold. Pain in the neck, but possible.
    Since you left the trans in the car, do you have something supporting it on the passenger side? Otherwise you'll likely find the clamp on the CV inner boot to be mashed up.
  18. #38 Re: Engine help
    MINNESOTA
    Nothing is holding the trans
    Can I use 2 by 4s to support it, or do I have to support the transmission itself
    It is the first time that I have pulled a engine out
    Done a couple of trans before but no engines till now
    Have one more question
    When I took the wheel barring out on the driver side I noticed that the CV axel came apart inside the boot that connects to the trans
    Is that normal
  19. #39 Re: Engine help
    anything that will lift the pass of the trans shaft up, and a bit higher will do.
    a jack will help lift/lower that side of the tranny so the bell housing lines up when you put the engine back in.
    and you need a new axle if im understanding you right.
  20. #40 Re: Engine help
    MINNESOTA
    I just bought the dang thing about 2 months ago
    I noticed that on the pass side it doesn't come apart like the driver side
    I wonder if I can contact rockauto and see if it has a warranty
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
