Thread: Engine help
Results 1 to 20 of 142
  1. #1 Re: Engine help
    Quote Originally Posted by valente View Post
    Fine, I will tell you how I broke it
    I was trying to separate the engine and trans, but had forgotten to take the 3 bolts off the torque converter
    I was working outside and it was about 90 degrees and I was tired
    Junk yard it is then
    that blows. it was hot as hell the two day i was ripping and replacing over. at least i was out of the sun in a garage, but it was still hot as balls.
    if your heads are ok dont touch the heads, i only did them cause i top swapped a n/a block. had no choice in the matter.
    i'd do the lower conversion kit. a lim gasket kit, upper plenum gasket and new valve cover gaskets. new coolant, oil and a filter.
  2. #2 Re: Engine help
    MINNESOTA
    Thanks
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
