Thread: Looking to degrease my engine
Results 1 to 20 of 35
  1. #1 Looking to degrease my engine
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    I recently was finally able to replace my valve cover gasket so now I want to get rid of the all the oil thats been pooling up for years. I bought O'Reilly heavy duty engine degreaser. Now a while ago, I was adding some oil to my car while it was hot and some oil spilled on the headers and started on fire. Lesson learned, but my question is, when I use the degreaser on the oil deposits and it lands on the headers, will that start on fire? Do I need to wash it off with a hose when I'm all one, and if so, what should I cover up, the alternator? Thanks.
  2. #2 Re: Looking to degrease my engine
    St. Louis
    Yep. I just cover the alt and spray away. Just don't use a pressure washer on it, lol.. Might get a stiff bristled brush for the baked on junk. Like the one you use for pots/pans. Should be at any dollar store. Scrubbed up my VC's nicely when I did it.
  3. #3 Re: Looking to degrease my engine
    Do with the engine cold and it won't be a cause for concern.
    Just spray everything down with degreaser and let it set, grab a old ****ty brush or something and start scrubbing. Let it sit for a few minutes and then hose it down. Everything can get wet under the hood, just be smart and not directly spray the alternator with water.
  4. #4 Re: Looking to degrease my engine
    get the car on ramps first, then get some old crappy cloths on, get under the car and spray the bottom of it down first, from the pass side wheel well you can spray the tranny down pretty good too. then spray the top down.
    let it sit how ever long the can says then i just spray it all down, but no direct blasting of the alt. its all water proof under the hood.
    if you have a compressor or a leaf blower, you can blow the water off the top of the engine when done. or just let it dry on its own.
  5. #5 Re: Looking to degrease my engine
    Apr 2015
    So just spray the offending areas and then brush it? I don't own a pressure washer so I'll be using a normal garden hose. I'll probably cover the alternator just to be on the safe side, but the electrical connectors don't need to be covered or anything?
  6. #6 Re: Looking to degrease my engine
    nope. all weather tight connections, spray at will.
    get like 2 or 3 cans too. one can is never enough. you'll be doing it two times easy. one can will soak the whole engine and bay well, but like i said, its never enough.
  7. #7 Re: Looking to degrease my engine
    Apr 2015
    Quote Originally Posted by ScottyDoggs View Post
    I got 2 cans because it was $5 for 2 and they're pretty large cans too so I think it will be enough.
  8. #8 Re: Looking to degrease my engine
    GT Level Member mguzzo's Avatar
    Buffalo NY
    the connectors are all weather-pak style so they will withstand splashing with the hose.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  9. #9 Re: Looking to degrease my engine
    Apr 2015
    Ok cool. Thanks guys.
  10. #10 Re: Looking to degrease my engine
    Mar 2014
    Tucson
    That "Super Clean" in the purple jug ($9) at Wal-Mart works great under the hood.
  11. #11 Re: Looking to degrease my engine
    oh, rule #1 here is to do this in a area you dont care about, if your engine is super nasty you'll leave a oil mess in your driveway and could stain it.
    if the hose reaches the street do it there, or over some grass or dirt area.
  12. #12 Re: Looking to degrease my engine
    Apr 2015
    I've got a pretty large piece of card board I was gonna use. It's like 6'x3' piece that I normally use when I lay on the ground and do work underneath. The road isn't the best option as the road I live on is really busy and I don't wanna get hit or something. Do you think the cardboard will catch most of the oil?
  13. #13 Re: Looking to degrease my engine
    it will help for sure. but its trash now lol time for that nice new cardboard box. wash the drive way down asap when done.
    i went through 5 large boxes doing my engine swap. had em as a floor covering under and a round the car. made sliding under it nice. and it caught all the mess i made.
  14. #14 Re: Looking to degrease my engine
    Apr 2015
    Yeah that cardboard piece is in the trash now. I used dish soap on the rainbow parts of the driveway. I also used a leaf blower to speed up the drying time. The worst part in my opinion is starting the engine and seeing all the smoke come up because you don't really know if it's the degreaser or excess oil burning off. I started it for like 30 seconds to make sure it still ran and then shut it off. Left the hood open to air dry some more. Looks good though.
  15. #15 Re: Looking to degrease my engine
    go get a few cheap cans of the foam wheel and tire degreaser/brake dust cleaner. Spray everything until its nice and white and foamy let it sit for a bit then hose it down.......
    i usually hose engine down with some tire foam and blast it out every few washes at home and rarely use drive through gateway to hell automatic car washes lol.....
  16. #16 Re: Looking to degrease my engine
    Apr 2015
    Quote Originally Posted by 98bleedingaholevet View Post
    Yeah I heard about the tire foam recently, but for $5, I was able to get 2 cans of heavy duty degreaser so I just went with that.
  17. #17 Re: Looking to degrease my engine
    i tried that tire foam crap once. ill never do it again. all it did was make the engine super dirty fast, as every last spec of dirt sticks to it.
  18. #18 Re: Looking to degrease my engine
    steam most likely. let it run its ok.
  19. #19 Re: Looking to degrease my engine
    Apr 2015
    Alright, but if it starts on fire and burns to the ground, it's your fault and you have to buy me a new car
  20. #20 Re: Looking to degrease my engine
    well lets not go that far lol you already know what oil smells like.
    keep in mind engine de greaser will make a stink once washed off and heated up. like a kerosene smell.
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
