Thread: Aeroforce problem
Results 1 to 8 of 8
  1. #1 Aeroforce problem
    Regal GS Level Member BoostedPontiac's Avatar
    Apr 2014
    South Haven, MI
    I wired the aeroforce up today and all seems to be going well except it doesn't display properly. It is setup for kr and water temp. The words show up but the numbers don't. Is this thing boned or what? I used an add a circuit fuse and everything is hooked up according the the guide on here.
    98' GP coupe NIC Pacesetters, E85, FSIC, 2.6, heads, blah
    11.82 @ 118.4 with a 1.8 60ft
    Retired: 99' Regal GS Turbo 11.428 @ 122.61 1.7 60ft.
    Retired: 99 GTP top swap nic setup. 13.37@106
  2. #2 Re: Aeroforce problem
    Oct 2011
    Toledo, OH
    It's receiving power, but no data. Check to see if your OBDII port is working.
    7"
  3. #3 Re: Aeroforce problem
    Apr 2014
    South Haven, MI
    I was following the instructions on here. It turns out my car needs both harnesses and the jumper clip to get it to work
  4. #4 Re: Aeroforce problem
    Oct 2011
    Toledo, OH
    Quote Originally Posted by BoostedPontiac View Post
    That can't be right. Removing the jumper cuts off the power received from the OBDII port so that you can use the harness. Using the harness AND the jumper means you are getting power from both the OBDII port AND from your switched 12v, which can damage the Aerofroce, or your OBDII port.
    Your OBDII port isn't working right, the fuse for it is probably blown, and running your gauge this way is putting 12v switched to the port and giving it power.
    7"
  5. #5 Re: Aeroforce problem
    SE Level Member Boilermaker894's Avatar
    Jan 2014
    Indiana
    Just cycle through the settings and go to them again
    Sent from my SAMSUNG-SGH-I337 using Tapatalk
    01 gtp special edition "special ed" k&n cai slp headers slp exhaust gen v ssic
  6. #6 Re: Aeroforce problem
    Apr 2014
    South Haven, MI
    OBD2 port reads DHP and my scangauge just fine. Seems weird but maybe thats just my car
  7. #7 Re: Aeroforce problem
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    same one that's forsale?
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  8. #8 Re: Aeroforce problem
    Oct 2011
    Toledo, OH
    Pretty strange indeed. As long as nothing starts smoking lol.
  1. Aeroforce Scan Gauge Problem
    By 2007GPGTSC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-27-2013, 09:10 AM
  2. WTT: red aeroforce for green aeroforce
    By monte0 in forum Wanted To Trade
    Last Post: 11-16-2013, 11:14 PM
  3. Older Aeroforce vs newer aeroforce
    By Lishap in forum General Grand Prix Discussion
    Last Post: 04-21-2013, 01:23 PM
  4. Problem with transmission NO REVERSE...Any suggestions of problem
    By newmy1d in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2012, 11:36 AM
  5. Aeroforce problem
    By windycitygtp in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2011, 01:41 PM
