Thread: A/C problem, light stays on, no cold air
Results 1 to 4 of 4
  1. #1 A/C problem, light stays on, no cold air
    Donating Users
    Aug 2013
    Michigan, USA
    For some reason my car's A/C won't work. It was working fine when I last used it last fall. I checked the pressure, I got normal in feron so it's not from leak.
    The A/C button (manual HVAC, not auto with dual climate) seems to be stuck in the on mode, the yellow A/C light remains on no matter how many times I pressed it. And the air coming from the vent is no colder than ambient air.
    Any idea why the A/C light is stuck on and where can I look for cause of A/C not cooling?
    2005 Pontiac GP, 3.8L NA
  2. #2 Re: A/C problem, light stays on, no cold air
    GXP Level Member
    Mar 2015
    Tomball
    I have the same AC controls as you. Fan, level, cold to hot knobs and 3 buttons. AC, recirculate, rear defrost.
    Pretty sure the reason the light stays on when the fan is on is that the switch is bad, mine worked fine for several days after I got the car then all of a sudden anytime I turn the fan on the AC comes on. Not a big deal right now, as it's about 762* here until December so I'll mess with soldering on a new switch then.
    Does the clutch come on? And when you checked the pressures what were they? High and low side pressures and the ambient temp outside?
    Jeff
  3. #3 Re: A/C problem, light stays on, no cold air
    SE Level Member chrisgotcrisco's Avatar
    May 2015
    well I was in the same situation you were in with the ac not working. For me it was the ac compressor not working and some other things and for total it was over $400. 04 Grand Prix GT 3.8L
  4. #4 Re: A/C problem, light stays on, no cold air
    GXP Level Member
    Mar 2015
    Tomball
    When you say checked the pressure and said "normal" what were your readings?
    Jeff
  1. Glove box light stays on
    By Panzer4 in forum General Tech Discussion
    Last Post: 05-29-2013, 03:32 PM
  2. tcs light stays on
    By doug g in forum General Tech Discussion
    Last Post: 03-06-2012, 09:27 PM
  3. stays in first gear for 5 min when engine is cold
    By chev1988rolet in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-11-2010, 11:43 PM
  4. ABS Light stays on
    By 2000 Pontiac GTP SC in forum Brakes/Suspension/Chassis
    Last Post: 10-04-2010, 10:57 AM
  5. Engine light stays on - '99 GT
    By 149GP in forum General Tech Discussion
    Last Post: 09-17-2008, 11:15 PM
