Thread: oil pressure gauge or vacuum gauge?
Results 1 to 8 of 8
  1. #1 oil pressure gauge or vacuum gauge?
    Feb 2015
    california
    I have one spot left. I have boost an aeroforce I need one more should I get oil pressure or vacuum glowshift gauge?
  2. #2 Re: oil pressure gauge or vacuum gauge?
    St. Louis
    If the Aeroforce can show oil pressure then I'd go vac. If not, then I'd go oil pressure. I like having an actual oil press. gauge in all my cars. Has saved me from some failures over the years.
  3. #3 Re: oil pressure gauge or vacuum gauge?
    Feb 2015
    california
    Not sure if aeroforce reads oil pressure or vaccume... Anyone know?
  4. #4 Re: oil pressure gauge or vacuum gauge?
    Dec 2013
    ohio
    Wideband. My boost gauge shows vac until you produce boost.
  5. #5 Re: oil pressure gauge or vacuum gauge?
    GTP Level Member chris99gtp's Avatar
    Jun 2012
    Illinois
    don't think aeroforce reads oil pressure. mine doesn't. Get a boost/vacuum gauge, ditch the boost gauge and run the oil pressure with that.
    99 gtp- Burnt and gone
    01 gtp- Here to stay-3.4, SD Headers, AL104's HAI, Overkill PCM, SD Hood
  6. #6 Re: oil pressure gauge or vacuum gauge?
    SWPA
    Oil pressure is even more important than boost.
  7. #7 Re: oil pressure gauge or vacuum gauge?
    oil pressure and a wideband are both 1/2 wired, waiting for my dash pod to come so i can finish the install.
  8. #8 Re: oil pressure gauge or vacuum gauge?
    Oct 2011
    Toledo, OH
    You need the oil pressure sender from Aeroforce in order for the gauge to read it. Our cars do not have a sensor for it.
    7"
  1. Boost gauge vacuum?
    By bigduck187 in forum General Grand Prix Discussion
    Last Post: 02-21-2013, 05:10 PM
  2. help installing oil pressure gauge and fuel pressure gauge
    By 03limitedgtp in forum General Tech Discussion
    Last Post: 02-06-2012, 07:23 AM
  3. What is Vacuum on a boost gauge ??
    Last Post: 04-07-2008, 12:54 PM
