Thread: stays in first gear for 5 min when engine is cold
Results 1 to 14 of 14
  1. #1 stays in first gear for 5 min when engine is cold
    SE Level Member chev1988rolet's Avatar
    Jul 2010
    TX
    This is a problem I have been dealing with for about a year and a half so I hope someone can help. Here it is, My transmission stays in first gear for atleast 5 minutes when I first start driving my car in the morning or when engine is cold. It will shift fine after that as long as I dont floor it when i am leaving a stop or a yield. can anyone help me out with this problem? One thing I can add is that when i am in first gear for the first time of the day. It dont feel like it gets all of first gear if thats makes any sense. Example, from a stop I accelerate slowly until about 19 mph and the rpms are at 3,000 then it just stops picking up speed and feels like i'm in neutral. I just cruise it until speed is at 10 mph then i accelerate again to about 20 mph and so on until second gear kicks in. I suspect the EPC or 1-2 shift solenoid since the resistance changes with temperature. I hope its not the first or second gear clutches. sorry for the long question. Can anyone help me cause I am eager to put my engine back in but can't cause I dont wanna bring it out again to fix the tranny.
  2. #2 Re: stays in first gear for 5 min when engine is cold
    It will help knowing the year and mileage of your car.
    Since you'd had this issue for a year, it's probably safe to say the clutches would have worn out by now. I'm thinking along the lines of a seal warming up or a solenoid. You can test the soleniods.
    Measure the resistance with the engine/trans cold (when it gives you the trouble) between pins
    A and E (Sol A)
    B and E (Sol B)
    Those are your two shift soleniods. Can't find it quick but the solenoids are like such (might have 2nd and 4th backwards)
    1st gear On On
    2nd gear Off On
    3rd gear Off Off
    4th gear On Off
    Looking at that, we can see that maybe one of them is sticking on and not allowing you into 2nd. Check the resistances hot and cold and report back.
  3. #3 Re: stays in first gear for 5 min when engine is cold
    Jul 2010
    TX
    ok thanks. I'm gonna check later on today when i borrow a voltmeter cause my son spilled coke on mine and f****d it up. good thing it was a cheap one. one question though, I read that resistance should be 19-24 cold and 24-31 hot. So does that mean resistance probably barely reaches 24 hot but is around 5-10 cold? kind of makes sense dont you think?
  4. #4 Re: stays in first gear for 5 min when engine is cold
    Just read them and codes for now. If the solenoids aren't in range, then we can chat about how far out of range is probably acceptable.
  5. #5 Re: stays in first gear for 5 min when engine is cold
    Jul 2010
    TX
    what about this I dont think my car goes into 4th gear cause I can be goin 75 mph and be reving at 3,500. the 1-2 solenoid is the same one for 3-4. well I'll post the update later on
  6. #6 Re: stays in first gear for 5 min when engine is cold
    Let's go ahead and get started on the other.
    Meanwhile when you are at 70mph what is your rpm? If you keep your right foot on the throttle lightly while cruising and touch the brake a little does the rpm come back up 200-500?
  7. #7 Re: stays in first gear for 5 min when engine is cold
    Jul 2010
    TX
    somewhere around 3,000. not sure exactly where since my car has been parked for about 3 months. the only accurate number is 55 mph at 1,800. rpm's just rise when i accelerate from there. I havent felt any shift after 55
  8. #8 Re: stays in first gear for 5 min when engine is cold
    SE Level Member icolex1's Avatar
    Feb 2009
    Highspire,PA
    did you ever figure out what it was? my '02 gt does this also
    hydro-powered
  9. #9 Re: stays in first gear for 5 min when engine is cold
    Jul 2010
    TX
    yea, I did transmission filter but found nothing on pan. opened filter and found clutch material. (looked like coffee grain but thicker.) Tranny finally gave out on me about 2 weeks ago. Now it dont go past 20 mph with revving. Just gonna get a junkyard tranny and hope for the best. you could check solenoids through side connector just to cancel them out. I did but they all turned out to be good.
  10. #10 Re: stays in first gear for 5 min when engine is cold
    Akron Ohio
    Quote Originally Posted by chev1988rolet View Post
    Try www.car-part.com I love that site
  11. #11 Re: stays in first gear for 5 min when engine is cold
    SE Level Member broncos's Avatar
    montreal
    my car has the same problem, i drive it around in second for about 5 minutes than when it shifts into secon for real it shifts ok after that, if i floor it it wont shift out of first unless i let go of the pedal
  12. #12 Re: stays in first gear for 5 min when engine is cold
    Jul 2010
    TX
    I think your problem could be debris on a shift valve or a bad solenoid. My clutches went out on me cause water got into my tranny 3 years ago.
  13. #13 Re: stays in first gear for 5 min when engine is cold
    montreal
    a tranny shop had told me it has something to do with a pressure thing inside the tranny what exactly he didnt know but said the tranny had to come down to fix it, havent done it yet
  14. #14 Re: stays in first gear for 5 min when engine is cold
    Jul 2010
    TX
    the pressure thing he's talking about is an epc solenoid. Its a solenoid that controls line pressure in an automatic transmission, and it might be easiet to drop the tranny a couple inches like he said to take off the side pan. there is some images online to let you know which is which but let me know if you cant find them.
  1. engine rattle on cold start up
    By justin1795 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-20-2010, 10:22 AM
  2. engine knocks when cold
    By Wolf02GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-09-2010, 07:03 AM
  3. engine revs when putting into gear
    By breeze12 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-07-2009, 09:28 AM
  4. Engine light stays on - '99 GT
    By 149GP in forum General Tech Discussion
    Last Post: 09-17-2008, 11:15 PM
  5. Engine running too cold?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2008, 07:41 PM
