Thread: Engine rebuild info request
Results 1 to 20 of 22
  1. #1 Engine rebuild info request
    Feb 2015
    Indiana
    So, I'm looking to buy a second engine to rebuild and drop in my 07 grand prix. When talking to a machine shop, what should I ask question wise to see if they're good, and what options should I ask them to perform on the block to get it ready to build? Thanks for the help guys.
  2. #2 Re: Engine rebuild info request
    I'd just get a low mileage short block and throw it in
  3. #3 Re: Engine rebuild info request
    gardner,mass
    These engines are so reliable stock it is not recommended to rebuild them because most people don't have luck with it. People push these blocks to 700+ whp on stock bottom end so if you need to just get a a low mileage one like dsmuts mentioned and throw that in.
    RPF1 17x9 255/45 Direzza Zll
    04 COMPG- Vs, getrag 284 RIP
  4. #4 Re: Engine rebuild info request
    Feb 2015
    Indiana
    I was actually hoping to build a 500ish hp engine, it was suggested that I rebuild the lower because of how high I wanted to go. If I am going to leave the lower stock, how much of it do you suggest I leave stock? I'm buying a n/a and looking to put a xpz cam in it first off. Should I get that professionally installed? I've yet to do anything like this but I really want to try, any help is greatly appreciated! Support is always helpful.
  5. #5 Re: Engine rebuild info request
    if you want 500 hp you want a turbo, a sc will not get you there.
    and just drop a used block in there. its not worth the shop costs and parts for no reason.
  6. #6 Re: Engine rebuild info request
    Kemmerer, Wyoming
    you will need an L67 or L32 for sure to support that much power. if it was me, and I wasn't driving the car every day, I would drop the engine and transmission out because the heads will have to come off for machine work, and the transmission will have to be built with some amazing parts to support that much power. then you can send the transmission to tep and the engine to whoever is going to cam it and put the heads on.
  7. #7 Re: Engine rebuild info request
    gardner,mass
    What scotty meens is the xpz is a blower cam. Your not going to reach 500 whp with a blower. Expect to spend around 4-7k to get to those goals and then 5+k for a trans build.
  8. #8 Re: Engine rebuild info request
    Quote Originally Posted by Ginseng View Post
    exactly. if your gonna go big plan big from the start, still dont need a rebuilt bottom end tho. but a pile of inheritance money does help lol
  9. #9 Re: Engine rebuild info request
    Quote Originally Posted by SgtMarshal View Post
    L36 bottom end would hold just fine. Stay away from the L26 if you want that much power or you will end up with this.
    This is a side by side comparison of the l36 and l67 connecting rod. L67 on top L36 on bottom.
    And L26
  10. #10 Re: Engine rebuild info request
    Enfield, CT
    Quote Originally Posted by Slick2500 View Post
    And L26
    L36 is stronger than the newer L26? I thought it was reverse. IIRC the rods were skinnier in the L26 but made of a stronger metal...
    Scotty, I want my L36 back.......
  11. #11 Re: Engine rebuild info request
    Feb 2015
    Indiana
    I know this is going to be one of those comments that makes a thread go nuts but.... I was planning on putting a htv 1900 in as the blower. I know it's a big project but like any real dreamer says "go big or go home". My car is a daily driver right now hence me wanting a second engine to do the mods to. I'll consider a turbo if I can't get the htv to do what I want tho.
  12. #12 Re: Engine rebuild info request
    Whatever you do...don't paint it up like a bumble bee.. lol
  13. #13 Re: Engine rebuild info request
    Enfield, CT
    lol
  14. #14 Re: Engine rebuild info request
    Feb 2015
    Indiana
    It's probably going to end up black, right now it's silver, the silver can stay for now.
  15. #15 Re: Engine rebuild info request
    hey!!!! i resemble that remark.
  16. #16 Re: Engine rebuild info request
    GTP Level Member L36 Killer's Avatar
    Jul 2012
    Harrisburg, Pennsylvania, United States
    Good luck with the build
    "SHELLY" GRAND PRIX GT 02. SLP HEADERS & EXHAUST, K&N CAI, BMR REAR SUSPENSION AND STRUT BRACES, 180 T-STAT, AGX STRUTS, EIBACH SPRINGS, OVERKILL PCM, YELLA TERRA 1.7 ROCKERS, GT1 CAM, SEXMAN PORTED & POLISHED HEADS, STAGE 2 PORTED TB
  17. #17 Re: Engine rebuild info request
    Feb 2015
    Indiana
    I know I'm going to need luck, there is a guy on 3800 pro that has done this already, I'm hoping he can steer me parts wise in the right direction.
  18. #18 Re: Engine rebuild info request
    I think snowflake did the TVS swap once.
  19. #19 Re: Engine rebuild info request
    Quote Originally Posted by HighOctaneRacing View Post
    From my understanding powdered metal sucks for connecting rods. Especially when they look like toothpicks.
  20. #20 Re: Engine rebuild info request
    May 2012
    Where winter never ends
    Good luck I'm around 500-600 wheel right now, just dropped on performance heads and a bigger cam. More power!
    2000 Regal - Winter Beater
  1. Engine Picture Request
    By JerzNick in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-26-2015, 12:08 PM
  2. Low engine vacuum at idle after engine rebuild
    By jbrltoliver in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-04-2013, 11:51 PM
  3. Need Service manual info post request here
    By jteske88 in forum General Tech Discussion
    Last Post: 03-30-2013, 09:03 AM
  4. Pic Request - 1997 GT Engine Bay
    By WillOverkill in forum General Tech Discussion
    Last Post: 04-22-2008, 10:29 PM
  5. Looking for Trans Rebuild Info
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2008, 12:03 AM
