Thread: Trans leak
Results 1 to 12 of 12
  1. #1 Re: Trans leak
    St. Louis
    Probably blew a line out. There are 2 on the trans case and 2 on the radiator. Fill it back up, have someone fire it up while you look.
  2. #2 Re: Trans leak
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Quote Originally Posted by FordMan77 View Post
    I think FordMan is on the right track. The lines have a little retaining clip on each end, if the clip breaks or comes off, the line can pop out and pour fluid out. New clips can be found in the "HELP!" section of auto parts stores.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  1. Trans line leak
    By K Slice in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-15-2014, 05:43 PM
  2. 08 GXP trans line leak
    By mrlogic1234 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2013, 12:57 PM
  3. Typical Gxp trans leak
    By jteske88 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-10-2012, 11:55 AM
  4. Trans Fluid Leak???
    By ill12will8 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-10-2010, 07:58 PM
  5. Trans Leak
    By stlmo_gtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-17-2009, 10:39 PM
