Thread: 02 GTP Fuse Box help
Results 1 to 3 of 3
  1. #1 02 GTP Fuse Box help
    Hi all,
    I need to get some info taking apart the fuse box in the engine compartment on a 2002 GTP 206K. Chasing a headlight issue that is resolved by a light tap on the fuse box cover.
    I can get to the point of loosening the three bolts on the back that seem to hold three large connector blocks.
    When the screws are all the way loose (clicking sound), the connectors are loose but will not come out of their frame.
    Not having done this before, is there anything I'm missing to get this apart the right way to see the actual connections under the fuses?
    I have not removed all of the fuses and relays.
    Thanks.
  2. #2 Re: 02 GTP Fuse Box help
    Jan 2015
    United States
    There are detents (bumps) on the side of the blocks that keep them from coming all the way out. Some gentle prodding with a screwdriver and you'll eventually see them.
  3. #3 Re: 02 GTP Fuse Box help
    Thanks Sparkydog,
    I didn't dig too hard as I was at the end of my knowledge.
    So I can assume those connectors will come out?
  1. ECU fuse
    By cmiranda in forum General Tech Discussion
    Last Post: 10-08-2013, 08:42 AM
  2. Fuse tap for wiper fuse.
    By Stormhaven in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2013, 12:24 PM
  3. What fuse is it?
    By asite57 in forum General Tech Discussion
    Last Post: 12-02-2011, 09:46 PM
  4. Big 3 fuse
    By c32k05 in forum Audio, Security & Visual Electronics
    Last Post: 04-21-2009, 02:06 PM
