you can cut a slot with a hacksaw in the bolt head or use a thin blade grinder then use a flat head screw driver.
when i do send out pcm, being im not a tuner, i delete codes as per the buyer, and install a trans tune set the vin# and such.
if you were closer i could do a in car tune. thats easy enough to do.
