Thread: 3800 Series II non-SC runs hot after replacing lower intake gaskets and upper intake
Results 1 to 20 of 34
  1. #1 Re: 3800 Series II non-SC runs hot after replacing lower intake gaskets and upper int
    Dec 2008
    Lawndale, CA
    I'm trying to remember what we did no my brothers 03. It was so long ago when we did the LIM. But I believe we taped the threaded part of the ECT and that fixed any issues he had with his sensor. I forget what brand he has. Perhaps something else you can try.
  2. #2 Re: 3800 Series II non-SC runs hot after replacing lower intake gaskets and upper int
    SE Level Member BrianP's Avatar
    Orange County, CA
    Quote Originally Posted by The Guz View Post
    "The Guz" can you elaborate on this? I'm not sure how taping the threads of the ECT would help the situation. I assume you are talking about using something like plumbing thread tape...??? The ECT that I purchased already had thread compound applied on the threads out of the box...
    To clarify: I don't have issues with the ECT leaking. I suspect that the new Duralast part that I have (which I bought a week ago, and have already replaced once since then) is producing a false reading causing an inaccurate needle reading on the instrument cluster, as well as causing the electric cooling fans to engage at 210-ish instead of the 185-ish temps that I have been used to seeing throughout the years.
    Thanks.
  1. Changed intake gaskets and now runs hot!
    By nd48463 in forum General Tech Discussion
    Last Post: 01-25-2014, 08:01 PM
  2. upper intake and lower intake manifold gasket
    By RICKS04GTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-22-2014, 12:06 PM
  3. Replies: 2
    Last Post: 03-31-2012, 07:49 PM
  4. Upper Intake Manifold and Lower Intake Manifold Replacement/Overhaul, due to leaks
    By McFly1999 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-29-2011, 03:25 AM
  5. Lower Intake Gaskets
    By predracer04 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-24-2011, 03:25 PM
