Thread: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
Results 1 to 16 of 16
  1. #1 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    May 2014
    Flint
    second issue i am having is the exterior molding on the drivers door is coming loose where it ends near the passenger door, It looks like a bolt or screw is in there when peeled back,
    I assume I have to remove the door card and secure the screw with a nut or washer?
    EDIT
    Looked into it and was recommended to use 3m molding super strenght tape, instead of popping off door card and seeing if this piece needs a washer or nut.
    here is a picture. http://i.imgur.com/Bm6PLKt.jpg
  2. #2 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    Flush the heater core, very common on the 04+ to have low heat output.
    They may be warm/hot but that doesnt mean they can flow enough hot coolant in there to keep it warm when you have the fans blasting.
  3. #3 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    May 2014
    Flint
    Bump for answer to second issue regarding molding, If the tape held and I didnt see the difference and it stays on forever thatd be great, I just feel like its not a proper fix but want to hear from you guys.
  4. #4 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    Nov 2013
    Wisconsin!
    It's held on with double sided tape anyway.....
  5. #5 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    May 2014
    Flint
    Is it? Thought that it wasn't due to the "bolt" or so,
  6. #6 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    GT Level Member Xorbex's Avatar
    Canada
    Its just a broken plastic body clip. Use the tape until it peels again and if you really want to fix it then the piece will have to be removed and you will need the proper clip from an auto parts store. Be sure to take the old clip with you to get an exact match. As far as getting it off im not sure if you have to rip the door apart but more than likely you will in order to get at the rear side of the clip to activate its release.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  7. #7 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    Jul 2010
    Coquitlam,BC,Canada
    This is how they are on the 97-03's.....
    http://chrisb.users.superford.org/Gr...r_Molding.html
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    May 2014
    Flint
    it looks like there is tape on top and bottom and a clip all together...... Ill see if any local body shops have done these and what they would run. if its $20-$40 ill probably go that route
    My dad said just to drop a little clear silicone to hold it so we will try that route.
  9. #9 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    Jan 2014
    AR
    I don't know squat about 06s so I haven't said anything, but... double sided tape might suprise you and hold. I'm not confident that an RTV goo will do. If theres something broken off the molding you might want to try your luck and stroll through a salvage yard because original paint matches fairly well from car to car. In any event, double sided automotive attachment tape can be a pain when its old. However if all the residue is cleaned off carefully, you can normally stick a molding corner back down if theres a flange to tape to. Did a little two inch at the front of my door fix last weekend. If tape doesn't hold forever it can be redone.
  10. #10 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    Nov 2013
    Wisconsin!
    Yes. There are little locating clips. And tape. It's easy and cheap. And if you clean both surfaces well before you stick it on. It will hold for quite a long time. Why spend money on a body shop.....it's a GP. Not a Bentley
  11. #11 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    May 2014
    Flint
    I got 3m molding tape the red kind should this be enough? And just slap her on there in warmer weather or?
  12. #12 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    Jul 2010
    Coquitlam,BC,Canada
    Make sure the surface is clean and warm; I use brake-clean and a heat gun.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  13. #13 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    Nov 2013
    Wisconsin!
    Making sure it's clean will be key to getting it to stick well.
  14. #14 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    May 2014
    Flint
    So clean it with brake cleaner on paint? Essentially use floss or peel slowly till its off, remove tape from both surfaces if any is on door and Re apply 3. Molding tape when it's hot out? I don't own a heatgun and feel like I'd do more damage with that is it necessary
  15. #15 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    Jan 2014
    AR
    Brake cleaner? Better wipe that off in a hurry, Bronc. That type of solvent can be absorbed into soft plastic and cause swelling. See can to confirm whether your specific chosen product is OK on car paint. To remove old tape, soften with solvent or lubricate with soapy water or glass cleaner and carefully scrape with a plastic instrument, maybe a used-up gift card or something like that. So you don't damage the paint. Solvents exist that can be used on modern clearcoat paint. Such as wax and grease or bug and tar remover, goo-gone, adhesive remover, nail polish remover, etc. But around the house I use WD40 while I scrape old tape. It stays wet for a spell, so you can scrape. Special "eraser wheel" or "hockey puck" tools are available for those who do it a lot. They work like a pencil eraser. Often a guy can slowly peel up the old tape with fingers if it is still in decent shape.
    Once the surfaces are free from tape, they can be cleaned. Wash first with soapy water (or squirt glass cleaner down in there, if the molding is still partially attached) and paper towel it as best you can then let it air out so at least your tape area is dry. Now you're ready for alcohol, to final clean. Isopropyl alcohol is cheap and at stores of all kinds and in varying strength. The place where you got that tape probably has some sort of packaged alcohol prep wipes just for this if you don't want a whole bottle.
    You'll be OK if its over 60 degrees, the 3M tape stays soft and sticks well. Heat makes it softer. Never a bad idea to keep an eye on a molding like that for a couple days in case it needs more pressing down though. They almost all (3M) have red backing (sometimes I see green liner on black tape) but you might have black, grey, or white foam tape in the package. They would all work. Just mash hell out of it when you stick it, and go over it a couple times just don't make a dent lol. If you do these things, you'll give it a sportin chance at staying put.
  16. #16 Re: 2006 grand prix 3.8 N/A Wimpy heat, door molding coming off,
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by idrivejunk View Post
    Been using/doing it this way for over 20 years with no bad results. Remember, we are only cleaning the surface, and brake clean evaporates quickly, so no issues. Now if we were soaking in it, that would be a different situation.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. 06 Grand Prix Front Door molding
    By brenglen in forum General Grand Prix Discussion
    Last Post: 06-22-2013, 02:48 AM
  2. Replies: 3
    Last Post: 02-15-2012, 05:23 PM
  3. 2006 Grand Prix front left door lock
    By walder1 in forum General Tech Discussion
    Last Post: 12-07-2011, 09:59 PM
