Thread: Driving issues
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 75
  1. #1 Driving issues
    Feb 2015
    Indiana
    So, I've come across 2 new problems on my 07 gp. The first is when I put the car in reverse it sounds like the right wheel pops. I have no idea why it does that. Second thing is I just got in my car to drive home and put it in drive, hit the gas, it made a gear grinding sound and the tcs came on. I think my cv joint is going out but any info would be great, thanks guys.
  2. #2 Re: Driving issues
    I'd jack up the front of the car and shake things down, check bearings and ball joints/control arm bushing for wear.
  3. #3 Re: Driving issues
    Feb 2015
    Indiana
    Full tie rods on both sides are brand new, everything else is factory, lower ball joints are neext on my list unless I need to change cvs right away.
  4. #4 Re: Driving issues
    St. Louis
    My 00 GT is making a popping noise on the drivers side right now when going into reverse and I know it's the CV axle. The pass. side did this for a while until I broke it one day. I'd def. do what FFDP said and get it in the air and check for play. Also may want to check the front sway bar for cracks. Not sure if they are like the 97-03's, but those were prone to cracking at the endlinks.
    If you plan on doing ball joints, then just get the entire control arm. That way you have new control arm bushings and ball joints at the same time. Check RockAuto and Amazon for some decent prices.
    If the axle is shot then grab a NAPA axle as they seem to last pretty well.
  5. #5 Re: Driving issues
    Enfield, CT
    NAPA axles are Cardone just so everyone knows
    Sent from my LG G3
  6. #6 Re: Driving issues
    Feb 2015
    Indiana
    I have the supercharged gt, does it matter which cv I get? I see the ac delco cv says it's the hd version, do I really have to pay 500 for a cv or can I get the cardone one with the hd boot on it?
  7. #7 Re: Driving issues
    Feb 2015
    Indiana
    Ok, it's doing it in forward and reverse now, could it be the transmission?
  8. #8 Re: Driving issues
    lower engine and tranny mount? dog bone bushings? check any of them?
    pop the hod, shift it from P to R then to D back to R, watch the engine, how much is it moving?
  9. #9 Re: Driving issues
    Feb 2015
    Indiana
    No offense, but I don't see how the mounts are making a grinding gear noise, it sounds like it's coming from the right front wheel.
  10. #10 Re: Driving issues
    never read the fist post. just went off the popping in and out of gear.
    it could be the diff is failing.
  11. #11 Re: Driving issues
    Feb 2015
    Indiana
    Differential or cv?
  12. #12 Re: Driving issues
    id get some one to shift in in and out of gear while i watched the cv joint. if your up on ramps you could get under there and maybe pin point where the sound is coming from.
    you can put your hand on the tranny and feel it for the pop sound too. stuff like that, your the eyes and ears, were not with the car. so everything is a educated guess at best.
  13. #13 Re: Driving issues
    Feb 2015
    Indiana
    Every symptom I looked up on the cv joint is what's going wrong with my car. This whole time I thought it was the suspension and have been working on it, but it's the cv joint. I think...
  14. #14 Re: Driving issues
    Feb 2015
    Indiana
    I have the 3.8 supercharged, is there a specific cv I need or will the regular cardone work?
  15. #15 Re: Driving issues
    Enfield, CT
    Just get the one that fits the supercharged engine. The transmission is a 4T65-E HD.
    Sent from my LG G3
  16. #16 Re: Driving issues
    Feb 2013
    37.295091, -121.930053
    dont forget that your tires maybe worn really funny so you may want to also look into new tires up front
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  17. #17 Re: Driving issues
    Feb 2015
    Indiana
    The tires have been on the list, just haven't gotten there due to previous problems.
  18. #18 Re: Driving issues
    Feb 2015
    Indiana
    Are the cv joints swappable from left to right? I'm failing to find a supercharger specific one for the left side. I know the 66-1256 is the supercharger specific right side version but Idk where the left is, or does it really matter?
  19. #19 Re: Driving issues
    Drivers side(left) is the same on pretty much every single 2nd gen w-body car. The passenger side(right) is different on the supercharged cars. CARDONE SELECT 661256
  20. #20 Re: Driving issues
    Enfield, CT
    Quote Originally Posted by Itchy2500 View Post
    Ummm no...
    Sent from my LG G3
  1. Tach dropped to 0 while driving and other issues
    By SliceTheRice in forum General Tech Discussion
    Last Post: 09-19-2012, 12:45 PM
  2. When your driving...
    By jer206 in forum General Grand Prix Discussion
    Last Post: 04-28-2012, 10:40 PM
  3. NEW MEMBER HELP PLEASE!! DCT codes and driving issues.
    By silver86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-08-2012, 10:05 PM
  4. Over Driving the SC
    By GreyGhost in forum General Tech Discussion
    Last Post: 01-30-2011, 07:32 PM
  5. while driving, BOC!
    By fst in forum The Rant Forum
    Last Post: 02-04-2008, 10:47 AM
