Thread: Need Help with 01 GP GT Stutter Video
Results 1 to 19 of 19
  1. #1 Need Help with 01 GP GT Stutter Video
    Nov 2014
    Beacon, NY
    So I have been chasing down a stutter and it's getting to the point where swapping parts isn't cost effective anymore.
    As stated in the video, I did new acdelco wires, new plugs, new throttle position sensor. I recently changed the fuel level sensor but not the whole fuel pump. I didn't do the fuel filter yet but I did buy one.
    I also bought one new coil and tried it in all three positions. Next I am thinking ignition control module but I don't want to buy that blind since it's over 100 bux.
    Any help is greatly appreciated.
    2001 Pontiac Grand Prix GT Stutter: https://youtu.be/Ho-RV3Cgeh0
    2014 Ford Focus ST
    2005 Honda Pilot EX-L
  2. #2 Re: Need Help with 01 GP GT Stutter Video
    Dec 2010
    DMV
    You try the maf?
  3. #3 Re: Need Help with 01 GP GT Stutter Video
    Nov 2014
    Beacon, NY
    You try the maf?
    I cleaned it, but it wasn't very dirty. But yeah that's another thought, also another part well over $100.
    2014 Ford Focus ST
  4. #4 Re: Need Help with 01 GP GT Stutter Video
    Dec 2010
    DMV
    Unplug it before starting the car. Then see if the stuttering continues
  5. #5 Re: Need Help with 01 GP GT Stutter Video
    Nov 2014
    Beacon, NY
    So unplug it, then drive with it unplugged? Thank you these are the exact types of tips I'm looking for. I will try that in a little bit here.
    2014 Ford Focus ST
  6. #6 Re: Need Help with 01 GP GT Stutter Video
    used icm's are cheap enough. most go for 20 bucks used around here. i cant hear it, but im sure you can feel it. ho wmany miles are on it?
    does it feel real weak when you get on it? the cel ever flash when its floored? if so maybe the cats clogged up.
  7. #7 Re: Need Help with 01 GP GT Stutter Video
    Nov 2014
    Beacon, NY
    No cel at all. It has 85000 miles and had the cat replaced at around 60k with an aftermarket one, and it did trip the cel but we backed it out and it's been off. I guess it could be clogged but there's no smell or anything.
    2014 Ford Focus ST
  8. #8 Re: Need Help with 01 GP GT Stutter Video
    Nov 2014
    Beacon, NY
    @bluemagic no luck maf unplugged and same result. Thanks though is there any easy ways to rule out other things?
    2014 Ford Focus ST
  9. #9 Re: Need Help with 01 GP GT Stutter Video
    could be the icm acting up on ya. or the wires to it maybe got damaged. is the ground for the icm hooked up? it bolts to the bracket there.
  10. #10 Re: Need Help with 01 GP GT Stutter Video
    Nov 2014
    Beacon, NY
    I will take a look. When I did the fuel level sensor I removed the relay for the fuel pump to relieve fuel pressure, so maybe I knocked something loose when removing the fuse panel cover? I'll check thanks.
    2014 Ford Focus ST
  11. #11 Re: Need Help with 01 GP GT Stutter Video
    did it have this issue before you changed the level sensor? or it started afterwards?
  12. #12 Re: Need Help with 01 GP GT Stutter Video
    Nov 2014
    Beacon, NY
    Pretty sure it started after the fuel pump, but not totally sure.
    2014 Ford Focus ST
  13. #13 Re: Need Help with 01 GP GT Stutter Video
    you can check your fuel pressure, but it would run like piss or barely run if the pump was bad. misfires are ignition related most of the time.
  14. #14 Re: Need Help with 01 GP GT Stutter Video
    Nov 2014
    Beacon, NY
    2001 Grand Prix GT Stutter Video 2: https://youtu.be/-U1WoV4V6gY
    2014 Ford Focus ST
  15. #15 Re: Need Help with 01 GP GT Stutter Video
    Nov 2014
    Beacon, NY
    I think at this point I will take it to my brother in laws shop, just hate having him swoop in and fix stuff I can't haha.
    2014 Ford Focus ST
  16. #16 Re: Need Help with 01 GP GT Stutter Video
    SE Level Member Hot wheels's Avatar
    Feb 2015
    Breckenridge TX
    Would a crank sensor cause any of these symptoms
  17. #17 Re: Need Help with 01 GP GT Stutter Video
    Nov 2014
    Beacon, NY
    Quote Originally Posted by Hot wheels View Post
    That's a great question, as I have the hard start after the car has warmed up symptom of a bad crank sensor, could my current issue stem from a bad sensor as well?
    2014 Ford Focus ST
  18. #18 Re: Need Help with 01 GP GT Stutter Video
    crank sensor is possible. seen a regal thread where it was missing from the c/s.
    the hard starting could be a dirty TB.
  19. #19 Re: Need Help with 01 GP GT Stutter Video
    Nov 2014
    Beacon, NY
    So just an update if anyone cares, under the advisement of the shop foreman at the honda dealer I work for, I removed the fuel rail and sprayed it and the fuel injectors with electronics cleaner. I put it back together and the stutter was gone. I sold the car a few days later so I was happy.
    2014 Ford Focus ST
  1. Stutter under full throttle?
    By Stevenhendrixjr in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-25-2013, 05:18 PM
  2. stutter start?
    By grandprix85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-26-2012, 02:10 PM
  3. Stutter when cold
    By gpse2000 in forum General Tech Discussion
    Last Post: 09-19-2011, 08:15 PM
  4. 05 GTP Comp G Engine Stutter
    By mrnodaysoff in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-30-2011, 08:22 AM
  5. 2000 SE 3.1L engine stutter
    By ejstark in forum General Tech Discussion
    Last Post: 06-30-2009, 01:03 PM
