Thread: NO spark on coil for 1st and 4th Cylinder
Results 1 to 3 of 3
  1. #1 NO spark on coil for 1st and 4th Cylinder
    SE Level Member damohr's Avatar
    Mar 2015
    Canada
    car threw a P0300 code and ran rough with check engine light flashing , after reading the code checking connectors i had a look at the coils and found that the 3rd coil for cylinder 1 and 4 is not producing sparks at all , i replaced the coil and still have the same issue , thinking it might be the ICM ( ignition control module) but i am not sure , 4 cylinders still get signals and sparks i don't think its a sensor but i don't have enough knowledge about that what i also don't know is if there is a fuse for the coils so if one goes the others still work? i really don't wanna start replacing everything just to find out it still there
  2. #2 Re: NO spark on coil for 1st and 4th Cylinder
    St. Louis
    No fuse for individual coils. Just swap one of the known working coils to it and see if the miss stays on 1/4. If so, I say ICM.
  3. #3 Re: NO spark on coil for 1st and 4th Cylinder
    Mar 2015
    Canada
    fixed the problem , got a used ICM from a junk yard for next to nothing put it in and its back to normal , thanks for the info !
  1. Spark plugs in cylinder 3 keep getting smashed. Pretty sure he spun a bearing
    By acidcrashdburnd in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2012, 12:56 PM
  2. Problem with cylinder 1 spark plug.. keeps going bad!
    By jstevanus in forum 5.3L V8 (LS4)
    Last Post: 07-23-2012, 09:52 PM
  3. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  4. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
  5. Ideas on How to Clean Coil connections/Spark Plug Wires
    By Panzer4 in forum General Tech Discussion
    Last Post: 10-19-2009, 11:30 PM
