Thread: Topswap question
Results 1 to 9 of 9
  1. #1 Topswap question
    GT Level Member TheDarkAngel's Avatar
    Oct 2013
    Iowa
    So I was wondering, after I topswap my 2000 GT, can I run a stock GTP PCM until I get mine tuned? I know I would have to do a security and case relearn, but that's no problem.
    First car- 1999 Buick Regal LS (Sold)
    Current ride- 2000 Grand Prix GT (The Dark Angel) DIY Intake, flipped bushings, visual stuffs, lowered on Eibachs, Topswap loading...........
  2. #2 Re: Topswap question
    May 2012
    Where winter never ends
    Code:
    A stock GTP pcm wont work unless you change the VIN and what not I dont think. You'll need at least a basic tune to start it.
    EDIT: The more I think about it, I dont see why it wouldnt... except the VINs being different...
    2000 Regal - Winter Beater
  3. #3 Re: Topswap question
    Mar 2012
    NC
    Trans gear ratio will be an issue...
  4. #4 Re: Topswap question
    Oct 2013
    Iowa
    Good point....hmmmm...there's no one around me to tune on a dyno or anything, so I have to get a canned tune from ZZP or somewhere.
  5. #5 Re: Topswap question
    Jul 2012
    Chicago
    Yeah, I wouldn't beat on it either. The motor would quickly pop with the stock timing.
    -Carl
  6. #6 Re: Topswap question
    Oct 2013
    Iowa
    I can adjust timing and everything at home, just no one around me tunes.
  7. #7 Re: Topswap question
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    When I did my '97 GT, I used that pcm and just adjusted the timing and fueling. Started with a stock timing table from an '02 GTP, and ran it rich to start off then slowly leaned it out. I also had an xp and ssic on there, and only a 3.5" pulley so I wasn't worried about kr. Without a powrtuner I wouldn't even have considered doing all that work, without a tuner, why not just go L67/hd swap and use the gtp pcm? Or is it already too late for that?
  8. #8 Re: Topswap question
    Oct 2013
    Iowa
    I've been looking around for canned tunes, and ZZP has theirs offered with either a topswap option (another $75), or their L36 Supercharger Kit option which is free...I know the kit comes with fuel logs, but would that change anything? I figured I can select the swap kit option and save $75 because it'll be the same?
  9. #9 Re: Topswap question
    Oct 2013
    Iowa
    I'll have the same plugs, and injectors, so I think it's the same?
  1. Question about current topswap
    By BlackGT97 in forum General Tech Discussion
    Last Post: 02-11-2013, 09:19 PM
  2. L36 to L67 topswap Idler pulley question
    By sumdude in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-01-2011, 02:53 AM
  3. topswap question
    By MakeitLouder97 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-07-2010, 10:18 PM
  4. Throttle Body Topswap question
    By SomeDudeAtHome in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-22-2010, 04:03 AM
  5. another topswap question...:)
    By hester21289 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-14-2008, 09:49 AM
