Thread: weird noise from the rear of car
Results 1 to 18 of 18
  1. #1 weird noise from the rear of car
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    So when I'm driving or even coming to a stop I hear a noise from the rear as if there's something rolling/sliding around back there. Struts are good but I'm beginning to think it's my strut mounts(KYBs bout 3yrs old from wbody store) but the front strut mounts are fine.
    What else could be loose or cause a loose sound in the rear(everything is tight from lug nuts up to strut mount bolts)?
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: weird noise from the rear of car
    St. Louis
    Something in the trunk loose (tools, jack, etc.), rear swaybar, trailing arms, emergency brake come to mind.
  3. #3 Re: weird noise from the rear of car
    Jul 2012
    North Philly
    Emergency brake is cool, nothing in my trunk that can make that much noise. Ironically the noise is only coming from the passenger side rear
  4. #4 Re: weird noise from the rear of car
    You say it's a rolling noise. Does that mean it happens as you are driving/stopping. Once stopped no noise. When you move again it starts up again?
    Kinda sounds wheel bearingish.
  5. #5 Re: weird noise from the rear of car
    GTP Level Member
    Aug 2012
    st louis park, MN
    It doesn't sound like the right noise, but check the emergency brake line. I secured mine with some zip ties as it was rattling around back there.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  6. #6 Re: weird noise from the rear of car
    Jul 2012
    North Philly
    Yeah Bill I'm leaning towards the wheel bearing also, after 15yrs never been changed it's a high possibility that that's the culprit. Only thing that's making me think it's not the wheel bearing is that the noise is intermittent(would be constant, for the most part if it was the wheel bearing).
    Usually happens when driving over a bump, once over the bump then the noise follows. Weird, just had car on the lift yesterday and everything underneath seems to be tight including the exhaust which is the first thing I checked.
    Hmmmmmmmmm, shouldn't nothing be in my spare tire area since I took that out a while back
  7. #7 Re: weird noise from the rear of car
    Donating Users jmak gtx2's Avatar
    Mableton, GA 30126
    Could be LCA bushing when on a lift it will be under load and seem tight or on the ground the same. You have to check using a jack on the ground to lift the body a few inches but leave the tire on the ground and then see if there is any play in the LCA or if you are on a lift coming down stop before the lift is free and the tire is on the ground. Good luck
  8. #8 Re: weird noise from the rear of car
    Jul 2012
    North Philly
    I'll take a look, but this sound is only coming from the rear of the vehicle. I would imagine if it was the LCA that I would hear this noise 24/7 on every take off or while braking beings though it is front wheel drive(especially with the way I drive).
    No LCA in the back, we do have trailing arms but mine are well greased through their grease fittings. Funny thing is that the noise is more of a rough drive over bump sound opposed to a dry bushing hinge sounding noise.....don't think it's the bushings but I'll still check anyway
  9. #9 Re: weird noise from the rear of car
    Dee..depending how pressure is on it.. it can be intermittent.
    Just turn the radio up and hope for the best.
  10. #10 Re: weird noise from the rear of car
    Jul 2012
    North Philly
    Yeah Bill, I find myself turning the music up pretty loud.
    I think it is the rear emergency break linings, I can just adjust/tighten the brake lining instead of replacing it correct?
  11. #11 Re: weird noise from the rear of car
    Jul 2012
    North Philly
    Or naw?
  12. #12 Re: weird noise from the rear of car
    jack the back wheels up, and spin em, see if you hear anything.
    only way the e brake is making noises is if they fell apart and are laying in the drum. does the e brake work?
    the rear calipers could be hanging up too.
  13. #13 Re: weird noise from the rear of car
    Jul 2012
    North Philly
    Parking brake works flawlessly, rear calipers hanging up?
  14. #14 Re: weird noise from the rear of car
    yeah, like they drag the rotor. ( dont release all the way) need to spin em and see if you hear anything.
  15. #15 Re: weird noise from the rear of car
    I stick to my previous statement. Turn the radio up.
    BTW Dee.. I've used mine as a tow truck recently....while the radio was up.
  16. #16 Re: weird noise from the rear of car
    GTP Level Member
    Aug 2012
    st louis park, MN
    Just stating the obvious, but have you looked at the rear pads and rotors for signs of excessive wear or damage?
  17. #17 Re: weird noise from the rear of car
    Sep 2014
    Worcester, MA
    I have seen many people who don't tighten down their spare tire well, and it bounces around.
    While you are checking it, make sure it is inflated to 60PSI.
  18. #18 Re: weird noise from the rear of car
    Jul 2012
    North Philly
    Funny, so I installed my new tires the other day and ironically I haven't heard the noise. My tires were bad but not bald.....2/32-3/32. May have been a belt shifting possibly....fooled me
  1. weird s/c noise
    By Orange04CompG in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2013, 02:01 PM
  2. Weird noise? help?
    By jman44 in forum Introductions/Noob Questions
    Last Post: 04-25-2013, 05:10 AM
  3. Weird noise?
    By Points70 in forum General Tech Discussion
    Last Post: 10-19-2011, 12:18 PM
  4. Weird Noise help!!!
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 12:31 PM
  5. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
