Thread: Weird noise?
Results 1 to 7 of 7
  1. #1 Weird noise?
    GT Level Member Points70's Avatar
    Nov 2010
    Bellevue, Nebraska, United States
    Ok on my way to school everything was fine, the after one class I had to drive to a different campus which is only about 1-2 miles away. And by the time I got there when ever I turn the wheel there is a loud hum. I'm assuming it has something to do with the power steering. Can this be caused by low power steering fluid? Or does this mean the pump is going bad?
  2. #2 Re: Weird noise?
    Could be either or...did you check it?
  3. #3 Re: Weird noise?
    Grand Rapids, MI
    Well have you checked the fluid?? It could be low...
    If the fluid is fine then maybe it's your pump maybe it's the rack.
  4. #4 Re: Weird noise?
    Might even be a bad wheel bearing. They typically make more noise with a load on the bearing.
  5. #5 Re: Weird noise?
    Nov 2010
    Sorry guys, I'm in class at the moment so I couldn't check it yet but when I'm out I will check it before I move the car again. And as far as the wheel bearing goes would it still make that noise when I'm parked but turning the wheel while the engine is on? I turned it and it stayed humming when it's not straight.
  6. #6 Re: Weird noise?
    Nope..bearings are only when moving.
  7. #7 Re: Weird noise?
    Nov 2010
    Ok that's what I was thinking. Thanks
  1. m90 making weird noise
    By gtp239 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-18-2011, 12:32 PM
  2. Weird noise
    By redgrandprix77 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-18-2011, 06:15 AM
  3. weird noise
    By c32k05 in forum Brakes/Suspension/Chassis
    Last Post: 07-23-2009, 10:47 AM
  4. Weird Noise help!!!
    By kappy332 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2008, 12:31 PM
  5. weird noise
    By bayareagtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-30-2008, 04:17 PM
