Thread: Transmission Question
Results 1 to 4 of 4
  1. #1 Transmission Question
    Jan 2015
    Ontario
    Newbie here in need of some help.
    I have a 2002 GTP tranny is slipping when I get on it.
    Can I use a tranny out of a regal or other Grand Prix that's not supercharged or are they different?
    Anyone know what other car has same tranny as a 2002 GTP supercharged?
    I'm told they are 2002 only from same car?! Help please
  2. #2 Re: Transmission Question
    St. Louis
    Anything from a GTP from 98-02 should work. 97 and 03 are different IIRC. Other W-body cars include the Regals, Monte's, Buick Park Avenue and Bonneville's. You have 2.93's stock in the GTP. One of the differences between the N/A cars and the supercharged ones is the H/D differential and the gear ratio.
    Depending on your budget you can get a great rebuild from tripleedgeperformance.com. Dave can set you up with a basic rebuild for a great price.
  3. #3 Re: Transmission Question
    97-02 HD transmissions are the same. 00+ has different trans cooler line fittings, an easy swap.
    A regal or bonneville/park ave can donate it's trans aswell but MUST come from a supercharged car to be a "DIRECT" swap. Research the years that you can use, but figure 98+ for regals and 2000-2002 for bonneville/park ave.
    You will not be able to use a regular non hd trans and have it be a turn key and go, there would need to be more changes done and 95% of people don't have the ability to make the changes.
  4. #4 Re: Transmission Question
    One thing not mentioned above is the trans line connection. 97-98 transmissions typically had threaded trans lines and the newer ones had click style. Not a deal breaker, but something to keep in mind. You have click's
  1. Transmission question
    By pinky in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-10-2014, 10:48 AM
  2. Transmission question
    By tgarison in forum General Tech Discussion
    Last Post: 09-28-2012, 09:11 PM
  3. used transmission question
    By jwhite85 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-02-2011, 03:39 PM
  4. Transmission question if anyone can help!!
    By chev1988rolet in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-28-2010, 10:39 PM
  5. question about my transmission
    By 01prixse in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 04-27-2009, 05:00 AM
