Thread: Noise when applying E brake
Results 1 to 5 of 5
  1. #1 Noise when applying E brake
    GT Level Member Pontiac Racer's Avatar
    Sep 2014
    U.S.A
    It was snowy in a parking lot so i decided to drift a bit being the juvanile high school kid i am. Well when i pushed the e brake down it makes this noise where it sounds like theres a big can of soda hitting the inside of the trunk. Im not sure why it does this. It does it every time no matter if i do it right after each other. Any ideas??
    '01 GT, OnStar antenna removed, GT emblem on grille, PONTIAC bumper inlay, engine cover and insulator removed, polished stock exhaust tips, 17" Bullitt rims
  2. #2 Re: Noise when applying E brake
    sounds like the wheels are still turning when the brakes on. pads are likely just metal back there. or out of adjustment.
    on dry ground, set the brake, put the car in gear and see if it will move when you gas it. if it does one of those two things are your issue.
    your e brakes are like a little drum brake inside the rear rotor.
  3. #3 Re: Noise when applying E brake
    Think about it, you are using an e-brake to lock the rear tires up. The e-brake shoes are trying to grab a spinning rotor, it's going to make noise.
    If it makes a noise when you arent moving and parking the car, then you need to inspect the parts and figure it out. Or just stop using it.
  4. #4 Re: Noise when applying E brake
    Sep 2014
    U.S.A
    Ok it shouldnt be making this loud banging noise. But ill investigate it more tomorrow. I was thinking they might be frozen but it does it one after the other so thats not likely. Im too concerned cause i guess it prevents me from drifting and thatll end up being a good thing in the long run lol.
  5. #5 Re: Noise when applying E brake
    Sep 2014
    U.S.A
    Not too concerned
  1. how much should my throttle plate open when applying gas?
    By Greg84 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-12-2014, 11:12 PM
  2. tranny issue while applying wide open throttle
    By getrdunn69 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-16-2013, 06:40 AM
  3. 2006 gp gxp right rear brake noise
    By bigtee in forum Brakes/Suspension/Chassis
    Last Post: 08-29-2012, 03:07 PM
  4. Brake Noise?
    By Kolton Lock in forum Brakes/Suspension/Chassis
    Last Post: 04-08-2012, 07:21 PM
  5. 03 gtp brake noise.
    By justin1795 in forum General Tech Discussion
    Last Post: 10-16-2010, 01:17 PM
