Thread: 2006 gp gxp right rear brake noise
Results 1 to 3 of 3
  1. #1 2006 gp gxp right rear brake noise
    Nov 2010
    baltimore,md
    2006 grand prix gxp right rear brake makes a clicking noise when brakes are applied pulled wheel off and inspected brake pads and rotors nothing wrong has anyone had this problem ?
  2. #2 Re: 2006 gp gxp right rear brake noise
    BAd pads?
    Are they cracked?
    Made they are not the right size and are loose in the caliper and clank around when you apply the brakes.
  3. #3 Re: 2006 gp gxp right rear brake noise
    Dec 2011
    Orlando, FL
    same issue with mine, a 2004GTP. i could not come up with an answer either so i had firestone check it out and the determination was made that my left rear caliper was leaking and basically about to fail. i confirmed this later by another visual inspection. autozone sells remanned calipers for $90 + $48 core charge. companies like firestone have a policy in place where they have to replace both at the same time; couple that with labor and you're looking at a grand. best bet is to get the remans and do it yourself, then get a $79 brake flush and the bleed will be included in the service.
  1. 2006 GXP issue with Low Brake Fluid Sensor light
    By ascotell in forum General Tech Discussion
    Last Post: 06-25-2012, 08:35 AM
  2. Replies: 3
    Last Post: 06-07-2012, 05:22 AM
  3. 2006 Special Edition Rear Fascia!!!!!
    By colindunn in forum Visual/Body Modifications
    Last Post: 03-30-2011, 04:33 PM
  4. 2006 GP Brake upgrades
    By BrianC636 in forum Brakes/Suspension/Chassis
    Last Post: 11-08-2009, 07:16 PM
  5. 2006 Grand Prix tranny noise in park & neutral
    By stevencharles32 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-16-2009, 12:52 PM
