Thread: taking forever to blow heat
Results 1 to 7 of 7
  1. #1 taking forever to blow heat
    Nov 2011
    Indiana, PA
    I've noticed the last two years my 2008 GP Base takes a long time to blow heat.
    If I set my HVAC to max heat and max blower start the car while the engine is cold, it takes about 15 minutes before the engine temp gauge starts to make it to the first tick mark, then it starts to go up to the 2nd tick mark and stays there.
    When it gets past the 1st tick mark I get warm air, and the 2nd it is hot, but when I first got this it took probably 5 minutes at most to get hot air.
    I replaced the thermostat in it, topped off the coolant thought it got a bit better but now it's back to taking 15+ minutes to warm up.
    Over summer I did notice when I do heavy acceleration on the highway you'd hear water rushing in the heater core, which I never heard before.
    I tried to burp it but seems like nothing helped, not sure if air is trapped in the core? I get heat but it takes forever.
    Also haven't had the coolant flushed yet, it's at 60k miles probably time for that also?
  2. #2 Re: taking forever to blow heat
    what temp t stat did you install? 195 is stock.
    your core has air trapped in it also, thats the water sounds. take both hoses off the alt bracket, take a garden hose to either hose and run the hose till clear water comes out the other hose, then put the hoses back on.
  3. #3 Re: taking forever to blow heat
    GTP Level Member
    Aug 2012
    st louis park, MN
    Start by back flush your heater core.
    take the heater core lines off the engine by the alt, then put a garden hose to one hose, turn it on till water flows out the other hose, then switch hoses, aka back flush the care, then put the hoses back on the engine. try to keep the hoses full of water when putting them back on.
    Once the car has reached normal operating temps, re bleed the air from the system.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  4. #4 Re: taking forever to blow heat
    GTP Level Member
    Aug 2012
    st louis park, MN
    I couldn't quote you fast enough! I'd second checking the thermostat you bought or simply replacing with a new 195.
  5. #5 Re: taking forever to blow heat
    Nov 2011
    Indiana, PA
    it was a 195 stat with new gasket
  6. #6 Re: taking forever to blow heat
    flush the core you'll be fine.
    also leaving the heat fan on 5 and letting it warm, your helping to slow the heat up time. the core is a little radiator, you run the fan it makes the coolant colder. run the fan on one or two. you'l have warm car in 10 minutes.
    or, just jump in it and drive after it idles for 2 or 3 minutes. all i do now a days. your'll save gas, they just drink it idling.
  7. #7 Re: taking forever to blow heat
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Also try not setting the heat to max, set it on low fan setting till it warms up some. I know my car if I leave the the blower off or on the lowest fan setting I get kickass heat in like 5-10min then crank it. If i leave the fan on max the car takes a long time to warm up.
    2012 F150 STX
    - Gonna be a race truck
  1. Heat Takes Forever
    By gordster1122 in forum General Tech Discussion
    Last Post: 11-24-2014, 01:29 PM
  2. Why does it take forever for my gt to heat up
    By raverockstar in forum General Grand Prix Discussion
    Last Post: 02-25-2013, 04:59 AM
  3. Taking forever to warm up
    By Moe Dubs in forum General Tech Discussion
    Last Post: 11-09-2012, 01:38 PM
  4. 06 GP dont blow much heat
    By AH06GrandPrix in forum General Grand Prix Discussion
    Last Post: 10-11-2012, 07:40 PM
  5. Tranny taking forever to shift from 2-3 and 3-od
    By kenizzle36 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-04-2011, 12:36 PM
