Thread: slight engine issue?
Results 1 to 4 of 4
  1. #1 slight engine issue?
    Apr 2013
    White Lake
    2005 GP GT 131k
    Today when I was driving home from work I stopped to get beer. When I turned on to my road I decided to accelerate to 70mph just for fun. When I stopped to let another person turn I noticed my car was shaking a little bit. I pulled into my car port and put the car in park and it was still shaking. RPMs were just over 500 and the lights were dimming a little as well. When I revved the engine over 700 rpms and it seemed fine but when I left off it would drop back down to low 500's. I got out and popped the hood and engine was shaking and it smelt different then normal. Didnt check oil but I know it is fine and 500 miles shy of oil change. I am very anal about maintaining my car well. No engine codes were thrown yet while it was happening. I'm going to wait a couple hours "check oil" and start it up to see if it is still happening.
  2. #2 Re: slight engine issue?
    Kinda seems like a misfire maybe or a vacuum line somehow popped off and causing it to chug.
    Maybe even a clogged converter, but hard to say without taking temp reading to see if it's getting way way hot before the cat.
  3. #3 Re: slight engine issue?
    GT Level Member hockeybawler's Avatar
    Oct 2011
    huntley
    My guess is you have a slight vacuum leak
  4. #4 Re: slight engine issue?
    Apr 2013
    White Lake
    Started the car a couple hours after the issue and it was running fine. Drove it a few times after that and no issues. I did notice now though that when I press the window button that everything dims in my car so im not sure if that is normal or my battery/alt is going bad?
  1. Engine Temp Issue
    By dpzelenak in forum 3.1L V6 (LHO/LG8)
    Last Post: 02-15-2016, 01:08 AM
  2. Engine Misfire Issue, HELP!
    By worshipmekaythnx in forum General Tech Discussion
    Last Post: 06-21-2012, 11:43 AM
  3. 98 GTP service engine light and slight hesitation?
    By Cobraeater in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-12-2012, 07:45 AM
  4. Trans or Engine issue
    By chuy09 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-20-2010, 07:55 AM
  5. 3.1l engine issue
    By 85burbanator in forum General Tech Discussion
    Last Post: 07-16-2010, 07:23 PM
