Thread: Horrible reception out of stereo
Results 1 to 4 of 4
  1. #1 Horrible reception out of stereo
    GTP Level Member Grandprix202's Avatar
    Apr 2013
    Fowlerville
    I have a kenwood ddx419 double din and as long as I've had the car I have had horrible reception. So I tore the back of my radio out and I'm looking at it and sure enough there is a wire that says 'ant cont' with nothing on it. I just need the find the antenna wire and connect it... Sounds easier said than done. I was wondering if anyone knew what color or where the antenna wire runs or comes through.
    Representing all the N/A out there. Fastest stock N/A you will ever come across.
  2. #2 Re: Horrible reception out of stereo
    Apr 2013
    Fowlerville
    The antenna wire comming from the stereo
    other wires comming from the harness thst aren't connected... Could one of these be it?
  3. #3 Re: Horrible reception out of stereo
    SWPA
    The antenna wire is meant for power antenna equipped cars. It would make the antenna raise when the stereo was on. Since you don't have a power antenna then that is not your issue.
  4. #4 Re: Horrible reception out of stereo
    Apr 2013
    Fowlerville
    Ahh alright that makes sense... I don't know why it's so bad. I thought i fixed it and then took it out of the garage and it was horrible again... So who knows. I know it's getting a signal becuse when I unplugged it it went 100% static.
  1. Bad reception
    By Grandprix202 in forum Audio, Security & Visual Electronics
    Last Post: 06-07-2013, 03:46 AM
  2. radio reception
    By echarleswhyte in forum Audio, Security & Visual Electronics
    Last Post: 10-12-2010, 08:48 PM
  3. AM Reception
    By mdkoh in forum Audio, Security & Visual Electronics
    Last Post: 06-17-2010, 12:32 AM
  4. Radio reception
    By 04muscle in forum 04+ Specifics
    Last Post: 02-25-2010, 08:50 PM
  5. 04 GTP getting poor xm reception
    By cbn4000 in forum Audio, Security & Visual Electronics
    Last Post: 07-18-2009, 04:22 PM
