Thread: 2005 GP GTP battery
Results 1 to 4 of 4
  1. #1 2005 GP GTP battery
    Jul 2012
    Bloomington, IL
    So the battery finally died in my 2005 GTP, and I'm attempting to replace it but I find that you must remove some things to get it out. My question is how do you remove the bolts that the black box (sorry, don't know the tech term for it) is bolted down with? They just keep turning and turning. It's almost like you have to get in the wheel well to keep the screws from turning.
    And then I'm assuming that you have to also remove the washer fluid container?
    Any help is appreciated. Thanks.
  2. #2 Re: 2005 GP GTP battery
    Aug 2013
    arlington, tx
    To remove the battery? You only need to unbolt the black piece that is holding the battery down at the case and the bar that crosses on top of the battery. That's it. And of course the wires that go to the battery.
  3. #3 Re: 2005 GP GTP battery
    Jul 2012
    Bloomington, IL
    Are you talking about the GTP that you only have to remove the bar? Because the fuse/relay needs to be removed or I can't get the battery out. Too small of an opening.
  4. #4 Re: 2005 GP GTP battery
    SWPA
    Yes the relay box needs unbolted and moved out of the way to get it out.
  1. 2005 battery cable ends
    By Madness in forum General Tech Discussion
    Last Post: 03-08-2015, 12:02 AM
  2. removing battery from 2005 grand prix!?!?!
    By Linebacker in forum General Tech Discussion
    Last Post: 12-12-2013, 03:40 PM
  3. 2005 cranks after new battery
    By LakersFan in forum General Tech Discussion
    Last Post: 11-08-2011, 12:40 PM
