Thread: 2005 cranks after new battery
Results 1 to 8 of 8
  1. #1 2005 cranks after new battery
    SE Level Member LakersFan's Avatar
    Sep 2011
    Ventura, CA
    Hey folks,
    My battery was dying a slow death so I decided to replace it today. Everything went well, except now when I start it, it cranks for about 1-2 secs before starting. Prior to the new battery, it started up right off the bat. Not really a big deal, but I don't know if it's the start of something bad... Any ideas?
    2005 Pontiac Grand Prix
  2. #2 Re: 2005 cranks after new battery
    Omaha, NE
    Do the old and new battery have the same CCA?
  3. #3 Re: 2005 cranks after new battery
    Sep 2011
    Ventura, CA
    Haha, this is embarrassing to admit, but I don't know. :/
    When my wife gets home I'll check the CCA of the new battery. The old battery was left at Costco.
    I really appreciate your help. Thanks!
  4. #4 Re: 2005 cranks after new battery
    Omaha, NE
    I would guess that since you bought it at costco, it's not a "high" quality battery, so the CCA is a little lower causing your change in starting.
    That's just a guess though.
  5. #5 Re: 2005 cranks after new battery
    im willing to say when you pulled the battery the pcm reset everything, last time i had the battery off my car it took a few cranks to get started,(this last one day) and the trans shifted oddly for a few days till it re learned how i drive.
    give it a day , it should be ok.
  6. #6 Re: 2005 cranks after new battery
    Sep 2011
    Ventura, CA
    Thanks to the both of you. I'll check the CCA and also give it a day or two to see if it goes back to normal. I'll let you know what happens....
  7. #7 Re: 2005 cranks after new battery
    Sep 2011
    Ventura, CA
    scottydogs was right. The problem resolved itself after a while... Thanks guys!
  8. #8 Re: 2005 cranks after new battery
    PA
    Also, the new battery might not have been fully charged. It might have only had 12 volts or so. Enough to start the car. But after a few charges it would start faster. Just a thought.
    Glad it worked itself out!
    2001 GSE
  1. Car Won't Start... Just Cranks.
    By Bedwards in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-22-2010, 10:23 PM
  2. Engine Cranks but Will not Start
    By rockytop104 in forum Introductions/Noob Questions
    Last Post: 10-04-2010, 08:21 PM
  3. cranks wont start
    By zach_gt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-19-2009, 08:10 PM
  4. Cranks over but will not start
    By wfj8251 in forum General Tech Discussion
    Last Post: 02-08-2009, 02:47 PM
  5. HELP! Cranks then Don't Crank
    By Bigboy49251 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-09-2009, 03:25 PM
