Thread: Does the '97-03 GTP require a PCV O-ring?
Results 1 to 7 of 7
  1. #1 Does the '97-03 GTP require a PCV O-ring?
    SE Level Member Centauri's Avatar
    Sep 2014
    St. Paul, MN
    As I've been tuning up my newly acquired '99 GTP and trying to chase down a formerly-sporadic 0171 code, I got to changing my PCV valve. After doing so the code has gone from sporadic to constant and I can't help but wonder if I was supposed to replace an o-ring and failed to do so?
    And I'm noticing that one of the GTP guides on Paul's site does specifically reference replacing "the spring and any o-rings or rubber gaskets" but I don't recall seeing any when I removed the valve I replaced.
    http://www.paulstravelpictures.com/G...ide/index.html
  2. #2 Re: Does the '97-03 GTP require a PCV O-ring?
    Kemmerer, Wyoming
    yes, there is an o ring, it goes around the shaft of the thicker part of the pcv
    I didn't replace mine, but I forgot to swap one over so not having it there was causing issues.
  3. #3 Re: Does the '97-03 GTP require a PCV O-ring?
    Sep 2014
    St. Paul, MN
    Thanks.
    Does anybody have a picture? Know where I can order one?
  4. #4 Re: Does the '97-03 GTP require a PCV O-ring?
    GTP Level Member
    Aug 2012
    st louis park, MN
    I would think a local store would be your best bet.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  5. #5 Re: Does the '97-03 GTP require a PCV O-ring?
    north carolina
    Click to Enlarge
    (Read reviews)
    Dorman PCV Valve Kit
    Sale Price:$13.38
    Quantity:
    (28) In Stock
    Part Number: 4725-07072901
    Notes: PCV Valve Kit
    Condition: New
    Shipping Options:
    Ground
  6. #6 Re: Does the '97-03 GTP require a PCV O-ring?
    north carolina
  7. #7 Re: Does the '97-03 GTP require a PCV O-ring?
    Sep 2014
    St. Paul, MN
    The MAF was testing well enough but replacing it got rid of my codes.
  1. Snap ring pliers for MAF screen retaining ring?
    By J7319M in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-08-2013, 06:26 AM
  2. i require a measurement!
    By Adasm in forum Brakes/Suspension/Chassis
    Last Post: 01-14-2013, 04:22 PM
  3. I require your vast knowledge!
    By 99PontiacGTP in forum General Tech Discussion
    Last Post: 09-08-2011, 07:49 PM
  4. CV axle: snap ring and abs ring
    By TheBeastGTP in forum General Tech Discussion
    Last Post: 09-13-2010, 03:47 PM
  5. Does CAI Require Cooler Plugs?
    By 08blackbase in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2010, 09:15 AM
