Thread: Electrical question
Results 1 to 5 of 5
  1. #1 Electrical question
    Nov 2014
    US
    I want to hook up a dash cam. The one I bought has a standard cigarette/accessory style plug, but I want to hardwire it to a switched circuit. Can I use a fuse tap to wire it in, and if so, which fuse would be the best one to tap in to? I've read a few posts where members suggest the sunroof, however I don't have one on my car. Thanks!
  2. #2 Re: Electrical question
    Mar 2014
    Tucson
    I'd recommend the "power drop" circuit. If you want to go dirt cheap, you could tap into those wires. Otherwise, ZZP sells a plug/harness. Makes for a clean install. I'm using that circuit and harness to power my Aeroforce.
    http://shop.zzperformance.com/store/...p-Harness.aspx
  3. #3 Re: Electrical question
    Nov 2014
    US
    I forgot to mention this is a 2006 Grand Prix. Is that power drop available for that year? If so, that looks like the way to go? I see three or four leads. One of those is a switched lead?
  4. #4 Re: Electrical question
    Mar 2014
    Tucson
    Oh, um... Can't say for sure on the '06. Best bet is to look behind/under the glove box. If it's there, you should see it right away.
    3 leads. According to the website, one is constant 12v, one is 12v with key on, and one is ground. I know for sure one is keyed 12v power and one is ground, cause that's what I used.
  5. #5 Re: Electrical question
    Nov 2014
    US
    I'll take a look tomorrow. Thanks, that would make life easier for me.
  1. Electrical question
    By Wtfalken in forum Introductions/Noob Questions
    Last Post: 05-26-2013, 02:14 PM
  2. HID electrical question.
    By bziggy58 in forum Audio, Security & Visual Electronics
    Last Post: 01-29-2013, 07:30 PM
  3. 02 grand prix electrical question
    By sjb in forum General Grand Prix Discussion
    Last Post: 08-22-2012, 08:23 AM
  4. Odd Electrical question
    By boostman in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2011, 02:08 PM
  5. Electrical Question
    By Kenny75k in forum Audio, Security & Visual Electronics
    Last Post: 04-03-2010, 07:46 PM
