Thread: Nasty gunk all over...
Results 1 to 3 of 3
  1. #1 Nasty gunk all over...
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    So I decided to take the long way to work since I got up an hour earlier than I needed to... Got up to about 50 mph cruising and the temp just kept climbing. Hit 260° and yelled at me right when i got into the parking lot, so after it cooled off i went to check the level and found some nasty brown goo on the bottom of the radiator cap... looks like a flush is in order, and the LIM and elbows are already in the mail. What i wanna know is how did you do it? And who had what kind of nastiness where? I want all of the horror stories.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  2. #2 Re: Nasty gunk all over...
  3. #3 Re: Nasty gunk all over...
    Pennsylvania, USA
    For the flush, a garden hose works well. Spray through the upper radiator hose, out of the bottom one into a bucket for both the radiator and the block (take out the thermostat first). It also wouldn't hurt to backflush the heater core, it's the two hoses that come off the belt tensioner.
    Spray until it comes out clear and refill to a 50/50 mix. If it's really bad, run straight water for a day or two and then flush again. And clean out the overflow tank since it's probably gummed up too.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  1. White/black/brownish gunk in radiator
    By Meliquin00 in forum Introductions/Noob Questions
    Last Post: 06-24-2013, 08:30 PM
  2. coolant low & gunk under radiator cap 2005 GT
    By mntnbiker in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-13-2013, 09:21 AM
  3. what is this gunk????
    By asite57 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2012, 09:18 PM
  4. Gunk in Radiator
    By mmcfearin in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-15-2008, 07:43 PM
